GRIP Help
Here is the error that I keep on getting
I am running 1.4.0 on a Kangaroo (I would update but I think a Kangaroo is only 32 bit)
ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
ERROR: V4L: setting property #16 is not supported
/usr/local/frc/JRE//bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/lvuser/grip.jar' '/home/lvuser/project.grip'
May 21, 2016 4:53:46 AM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
CONFIG: GRIP Version: 1.4.0
platform: /Linux/arm/
May 21, 2016 4:53:52 AM edu.wpi.grip.core.Main start
INFO: Loading file /home/lvuser/project.grip
May 21, 2016 4:53:54 AM edu.wpi.grip.core.util.service.LoggingListener starting
INFO: [CameraSource] Starting
May 21, 2016 4:53:54 AM edu.wpi.grip.core.operations.composite.PublishVideoOperation lambda$new$0
INFO: Starting camera server
May 21, 2016 4:53:55 AM edu.wpi.grip.core.util.service.LoggingListener starting
INFO: [PipelineRunner] Starting
May 21, 2016 4:53:55 AM edu.wpi.grip.core.Main start
INFO: SUCCESS! The project is running in headless mode!
OpenCV Error: Assertion failed (ssize.area() > 0) in resize, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp, line 3208
May 21, 2016 4:53:55 AM edu.wpi.grip.core.Step runPerformIfPossible
WARNING: The CV resize operation did not perform correctly.
java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp:3208: error: (-215) ssize.area() > 0 in function resize
	at org.bytedeco.javacpp.opencv_imgproc.resize(Native Method)
	at edu.wpi.grip.generated.opencv_imgproc.Resize.perform(Resize.java:61)
	at edu.wpi.grip.core.Operation.perform(Operation.java:92)
	at edu.wpi.grip.core.Step.runPerformIfPossible(Step.java:152)
	at edu.wpi.grip.core.PipelineRunner.runPipeline(PipelineRunner.java:184)
	at edu.wpi.grip.core.PipelineRunner.access$100(PipelineRunner.java:35)
	at edu.wpi.grip.core.PipelineRunner$1.runOneIteration(PipelineRunner.java:68)
	at com.google.common.util.concurrent.AbstractScheduledService$ServiceDelegate$Task.run(AbstractScheduledService.java:189)
	at com.google.common.util.concurrent.Callables$3.run(Callables.java:100)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
May 21, 2016 4:53:55 AM edu.wpi.grip.core.Main onExceptionEvent
SEVERE: The CV resize operation did not perform correctly.
WARNING: The HSL Threshold operation did not perform correctly.
java.lang.IllegalArgumentException: HSL Threshold needs a 3-channel input
	at edu.wpi.grip.core.operations.composite.HSLThresholdOperation.perform(HSLThresholdOperation.java:68)
SEVERE: The HSL Threshold operation did not perform correctly.
VIDEOIO ERROR: V4L/V4L2: VIDIOC_S_CROP
VIDEOIO ERROR: V4L: setting property #16 is not supported
May 21, 2016 4:53:55 AM edu.wpi.grip.core.operations.network.networktables.NTManager lambda$new$0
INFO: NetworkTables: Dispatcher.cpp:392 client: CONNECTED to server 172.22.11.2 port 1735
May 21, 2016 4:53:56 AM edu.wpi.grip.core.Main onExceptionClearedEvent
INFO: Exception Cleared Event
OpenCV Error: Insufficient memory (Failed to allocate 921600 bytes) in OutOfMemoryError, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/core/src/alloc.cpp, line 52
OpenCV Error: Assertion failed (u != 0) in create, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/core/src/matrix.cpp, line 411
May 21, 2016 4:55:01 AM edu.wpi.grip.core.util.service.LoggingListener starting
VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
VIDIOC_STREAMON: Bad file descriptor
May 21, 2016 4:55:01 AM edu.wpi.grip.core.GRIPCoreModule onThreadException
SEVERE: Uncaught Exception on thread Thread[Webcam 0 Service,5,main]
java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/core/src/matrix.cpp:411: error: (-215) u != 0 in function create
	at org.bytedeco.javacpp.opencv_videoio.cvRetrieveFrame(Native Method)
	at org.bytedeco.javacv.OpenCVFrameGrabber.grab(OpenCVFrameGrabber.java:237)
	at edu.wpi.grip.core.sources.GrabberService.runOneGrab(GrabberService.java:69)
	at edu.wpi.grip.core.sources.GrabberService.run(GrabberService.java:61)
	at com.google.common.util.concurrent.AbstractExecutionThreadService$1$2.run(AbstractExecutionThreadService.java:60)
May 21, 2016 4:55:01 AM edu.wpi.grip.core.util.service.LoggingListener failed
SEVERE: [CameraSource] Failed from: RUNNING
SEVERE: [CameraSource] Failed from: STARTING
edu.wpi.grip.core.sources.GrabberService$GrabberServiceException: [Webcam 0] Failed to start
	at edu.wpi.grip.core.sources.GrabberService.startUp(GrabberService.java:51)
	at com.google.common.util.concurrent.AbstractExecutionThreadService$1$2.run(AbstractExecutionThreadService.java:54)
Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?)
	at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenCVFrameGrabber.java:214)
	at edu.wpi.grip.core.sources.GrabberService.startUp(GrabberService.java:49)
	... 3 more
May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent
SEVERE: Camera service crashed
	... 3 more
May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting
May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
Unable to stop the stream.: Bad file descriptor
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
	... 3 more
Unable to stop the stream.: Device or resource busy
VIDIOC_QUERYCTRL: Bad file descriptor
	... 3 more
	... 3 more
	... 3 more
[ERROR] Too much output to display. Discarding the rest.
\CODE]
The "VIDIOC_QUERYCTRL: Bad file descriptor" is since i turned off the robot
grip:Pipeline
grip:Camera
</grip:Camera>
<grip:Step name=“Publish Video”>
<grip:Input step=“0” socket=“0”/>
<grip:Input step=“0” socket=“1”>
80.0
</grip:Input>
</grip:Step>
<grip:Step name=“Publish Number”>
<grip:Input step=“1” socket=“0”/>
<grip:Input step=“1” socket=“1”>
frameRate
</grip:Input>
<grip:Input step=“1” socket=“2”>
true
</grip:Input>
</grip:Step>
<grip:Step name=“CV resize”>
<grip:Input step=“2” socket=“0”/>
<grip:Input step=“2” socket=“1”/>
<grip:Input step=“2” socket=“2”>
0.6
</grip:Input>
<grip:Input step=“2” socket=“3”>
0.6
</grip:Input>
<grip:Input step=“2” socket=“4”>
INTER_LINEAR
</grip:Input>
<grip:Output step=“2” socket=“0” previewed=“false”/>
</grip:Step>
<grip:Step name=“HSL Threshold”>
<grip:Input step=“3” socket=“0”/>
<grip:Input step=“3” socket=“1”>
53.41726618705036
100.0
</grip:Input>
<grip:Input step=“3” socket=“2”>
38.98381294964029
222.36348122866895
</grip:Input>
<grip:Input step=“3” socket=“3”>
105.48561151079136
215.83617747440272
</grip:Input>
<grip:Output step=“3” socket=“0” previewed=“false”/>
</grip:Step>
<grip:Step name=“Find Contours”>
<grip:Input step=“4” socket=“0”/>
<grip:Input step=“4” socket=“1”>
false
</grip:Input>
<grip:Output step=“4” socket=“0” previewed=“false”/>
</grip:Step>
<grip:Step name=“Filter Contours”>
<grip:Input step=“5” socket=“0”/>
<grip:Input step=“5” socket=“1”>
0.0
</grip:Input>
<grip:Input step=“5” socket=“2”>
0.0
</grip:Input>
<grip:Input step=“5” socket=“3”>
0.0
</grip:Input>
<grip:Input step=“5” socket=“4”>
1000.0
</grip:Input>
<grip:Input step=“5” socket=“5”>
0.0
</grip:Input>
<grip:Input step=“5” socket=“6”>
1000.0
</grip:Input>
<grip:Input step=“5” socket=“7”>
0
100
</grip:Input>
<grip:Output step=“5” socket=“0” previewed=“true”/>
</grip:Step>
<grip:Step name=“Publish ContoursReport”>
<grip:Input step=“6” socket=“0”/>
<grip:Input step=“6” socket=“1”>
myContoursReport
</grip:Input>
<grip:Input step=“6” socket=“2”>
true
</grip:Input>
<grip:Input step=“6” socket=“3”>
true
</grip:Input>
<grip:Input step=“6” socket=“4”>
true
</grip:Input>
<grip:Input step=“6” socket=“5”>
true
</grip:Input>
<grip:Input step=“6” socket=“6”>
true
</grip:Input>
<grip:Input step=“6” socket=“7”>
true
</grip:Input>
</grip:Step>
grip:Connection
</grip:Connection>
grip:Connection
</grip:Connection>
grip:Connection
<grip:Output source=“0” socket=“0” previewed=“false”/>
</grip:Connection>
grip:Connection
</grip:Connection>
grip:Connection
<grip:Output source=“0” socket=“1” previewed=“false”/>
</grip:Connection>
grip:Connection
</grip:Connection>
grip:Connection
</grip:Connection>
0
roborio-0-frc.local
10.36.47.2
/home/lvuser
lvuser
/usr/local/frc/JRE/
</grip:Pipeline>
That is my grip config
Can someone help me debug
Please open an issue on Github for support from the GRIP team.
Unfortunately, this issue has been reported numerous times it looks like. I haven’t seen any solutions yet either. Are there any solutions yet that anyone is aware of? Our team just started working with GRIP for the summer and so I don’t really know how to continue if we’re running into this known problem.
