Hi! This is my first post, so dont yell at me If I did something wrong. When I was coding my camera code in my main Robot class, I ran into an error for creating the rectangle.
Code:
package org.usfirst.frc.team193.robot;
import com.ctre.CANTalon;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.CameraServer;
import org.opencv.core.KeyPoint;
import org.opencv.core.MatOfKeyPoint;
import org.opencv.core.Rect;
import org.opencv.imgproc.Imgproc;
import edu.wpi.cscore.UsbCamera;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.vision.VisionRunner;
import edu.wpi.first.wpilibj.vision.VisionThread;
The VM is configured to automatically run this class, and to call the
functions corresponding to each mode, as described in the IterativeRobot
documentation. If you change the name of this class or the package after
creating this project, you must also update the manifest file in the resource
directory.
final String defaultAuto = “Default”;
final String customAuto = “My Auto”;
String autoSelected;
SendableChooser<String> chooser = new SendableChooser<>();
Joystick leftJoy = new Joystick(0);
Joystick rightJoy = new Joystick(1);
double leftValue;
double rightValue;
CANTalon leftMaster = new CANTalon(2);
CANTalon rightMaster = new CANTalon (5);
private static final int IMG_WIDTH = 320;
private static final int IMG_HEIGHT = 240;MatOfKeyPoint blobsOutput = new MatOfKeyPoint();
private VisionThread visionThread;
private double centerX = 0.0;
private RobotDrive drive;private final Object imgLock = new Object();
This function is run when the robot is first started up and should be
used for any initialization code.
@Override
public void robotInit() {
chooser.addDefault(“Default Auto”, defaultAuto);
chooser.addObject(“My Auto”, customAuto);
SmartDashboard.putData(“Auto choices”, chooser);UsbCamera camera = CameraServer.getInstance().startAutomaticCapture();
camera.setResolution(IMG_WIDTH, IMG_HEIGHT);visionThread = new VisionThread(camera, new Pipeline(), pipeline -> { if (!pipeline.findBlobsOutput().empty()) { Rect r = Imgproc.boundingRect(pipeline.findBlobsOutput().get(0, 0)); synchronized (imgLock) { centerX = r.x + (r.width / 2); } } }); visionThread.start();
- This autonomous (along with the chooser code above) shows how to select
- between different autonomous modes using the dashboard. The sendable
- chooser code works with the Java SmartDashboard. If you prefer the
- LabVIEW Dashboard, remove all of the chooser code and uncomment the
- getString line to get the auto name from the text box below the Gyro
- You can add additional auto modes by adding additional comparisons to the
- switch structure below with additional strings. If using the
- SendableChooser make sure to add them to the chooser code above as well.
@Override
autoSelected = chooser.getSelected();
// autoSelected = SmartDashboard.getString(“Auto Selector”,
// defaultAuto);
System.out.println("Auto selected: " + autoSelected);
This function is called periodically during autonomous
@Override
switch (autoSelected) {
case customAuto:
if (!blobsOutput.empty()){
KeyPoint KPArray] = blobsOutput.toArray();
double centerX;
centerX = this.centerX;
double turn = centerX - (IMG_WIDTH / 2);
drive.arcadeDrive(-0.6, turn * 0.005);} break;case defaultAuto:
default:
// Put default auto code here
break;
- This function is called periodically during operator control
@Override
leftValue = leftJoy.getY();
rightValue = rightJoy.getY();
leftMaster.set(-leftValue);
rightMaster.set(rightValue);
- This function is called periodically during test mode
@Override
public void testPeriodic() {
ERROR: the method boundingRect(MatOfPoint) in they type Imgproc is not applicable for the type double].
Any help would be greatly appreciated. Thank you!
