GRIP with kangaroo
We are trying to use grip with a Kangaroo. We have followed the screensteps documentation but it doesn’t have a lot of information about running grip on startup. We are using this code to try and send values from the kangaroo network tables to the rio network tables:
import edu.wpi.first.wpilibj.networktables.NetworkTable;
public class main {
	public static void main(String] args){
		NetworkTable localTable;
		NetworkTable rioTable;
		while(true){
			NetworkTable.setClientMode();
			localTable = NetworkTable.getTable("localhost");
			rioTable = NetworkTable.getTable("10.10.24.62");
			double] centerx =localTable.getNumberArray("centerX", new double[0]);
			double] centery =localTable.getNumberArray("centerY", new double[0]);
			double] area =localTable.getNumberArray("area", new double[0]);
			double] height =localTable.getNumberArray("height", new double[0]);
			double] width =localTable.getNumberArray("width", new double[0]);
			double] solidity =localTable.getNumberArray("solidity", new double[0]);
			for (int i = 0; i < centerx.length; i++) {
				rioTable.putNumber("CenterX", centerx*);
			for (int i = 0; i < centery.length; i++) {
				rioTable.putNumber("CenterY", centery*);
			for (int i = 0; i < area.length; i++) {
				rioTable.putNumber("Area", area*);
			for (int i = 0; i < height.length; i++) {
				rioTable.putNumber("Height", height*);
			for (int i = 0; i < width.length; i++) {
				rioTable.putNumber("Width", width*);
			for (int i = 0; i < solidity.length; i++) {
				rioTable.putNumber("Solidity", solidity*);
we get this error when compiling:
platform: /Windows/amd64/
Exception in thread "main" java.lang.UnsatisfiedLinkError: no ntcore in java.library.path
	at java.lang.ClassLoader.loadLibrary(Unknown Source)
	at java.lang.Runtime.loadLibrary0(Unknown Source)
	at java.lang.System.loadLibrary(Unknown Source)
	at edu.wpi.first.wpilibj.networktables.NetworkTablesJNI.<clinit>(NetworkTablesJNI.java:57)
	at edu.wpi.first.wpilibj.networktables.NetworkTable.initialize(NetworkTable.java:42)
	at edu.wpi.first.wpilibj.networktables.NetworkTable.getTable(NetworkTable.java:176)
	at main.main(main.java:9)
If someone knows a way to do this or a solution to our code, please let us know.******
You’re likely using a NetworkTables jar file for the roboRio instead of for Windows. You should grab the latest -desktop.jar file from http://first.wpi.edu/FRC/roborio/maven/release/edu/wpi/first/wpilib/networktables/java/NetworkTables/3.0.0-SNAPSHOT/
Also, I’m not sure what you’re trying to accomplish with the lines localTable = NetworkTable.getTable(“localhost”); rioTable = NetworkTable.getTable(“10.10.24.62”);. The roboRio is the server, so you just need to set the server address, upon connection, all tables will be communicated/synchronized between all clients connected to that server.
