I am trying to use GRIP with my USB camera. I know the camera works and is configured correctly but, with my input set to webcam 0 it says it can not find the camera.
What source must I use to access my USB camera?
What’s the exact error message that happens when you create a camera source?
This is the part that I believe you are looking for.
WARNING: Failed to initialize CameraSource
java.io.IOException: A problem occurred trying to start the frame grabber for Webcam 0
This is the full error
Loading Dependency Injection Framework
Jan 19, 2016 1:59:31 AM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
platform: /Linux/arm/
Jan 19, 2016 1:59:41 AM edu.wpi.grip.core.Main start
INFO: Loading file test.grip
Jan 19, 2016 1:59:45 AM edu.wpi.grip.core.Source initializeSafely
at edu.wpi.grip.core.sources.CameraSource.start(CameraSource.java:191)
at edu.wpi.grip.core.sources.CameraSource.initialize(CameraSource.java:174)
at edu.wpi.grip.core.Source.initializeSafely(Source.java:98)
at edu.wpi.grip.core.serialization.SourceConverter.unmarshal(SourceConverter.java:60)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:72)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:66)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:50)
at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readItem(AbstractCollectionConverter.java:71)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.addCurrentElementToCollection(CollectionConverter.java:98)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:91)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:85)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.unmarshal(CollectionConverter.java:80)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshallField(AbstractReflectionConverter.java:480)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doUnmarshal(AbstractReflectionConverter.java:412)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshal(AbstractReflectionConverter.java:263)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:134)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1206)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1190)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1061)
at edu.wpi.grip.core.serialization.Project.open(Project.java:68)
at edu.wpi.grip.core.serialization.Project.open(Project.java:62)
at edu.wpi.grip.core.Main.start(Main.java:53)
at edu.wpi.grip.core.Main.main(Main.java:35)
Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?)
at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenCVFrameGrabber.java:214)
at org.bytedeco.javacv.FrameGrabber.restart(FrameGrabber.java:430)
at edu.wpi.grip.core.sources.CameraSource.start(CameraSource.java:189)
... 28 more
Jan 19, 2016 1:59:45 AM edu.wpi.grip.core.Main onExceptionEvent
SEVERE: Failed to initialize CameraSource
... 28 more
SEVERE: src must have a value to run this step.
SEVERE: Input must have a value to run this step.
SEVERE: Value must have a value to run this step.
Jan 19, 2016 1:59:46 AM edu.wpi.grip.core.Main onExceptionClearedEvent
INFO: Exception Cleared Event
Jan 19, 2016 1:59:46 AM edu.wpi.grip.core.Step runPerformIfPossible
WARNING: The CV resize operation did not perform correctly.
java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp:3208: error: (-215) ssize.area() > 0 in function resize
at org.bytedeco.javacpp.opencv_imgproc.resize(Native Method)
at edu.wpi.grip.generated.opencv_imgproc.Resize.perform(Resize.java:58)
at edu.wpi.grip.core.Operation.perform(Operation.java:61)
at edu.wpi.grip.core.Step.runPerformIfPossible(Step.java:137)
at edu.wpi.grip.core.Step.onInputSocketChanged(Step.java:156)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:483)
at com.google.common.eventbus.EventSubscriber.handleEvent(EventSubscriber.java:74)
at com.google.common.eventbus.SynchronizedEventSubscriber.handleEvent(SynchronizedEventSubscriber.java:47)
at com.google.common.eventbus.EventBus.dispatch(EventBus.java:322)
at com.google.common.eventbus.EventBus.dispatchQueuedEvents(EventBus.java:304)
at com.google.common.eventbus.EventBus.post(EventBus.java:275)
at edu.wpi.grip.core.serialization.ConnectionConverter.unmarshal(ConnectionConverter.java:58)
Jan 19, 2016 1:59:46 AM edu.wpi.grip.core.Main onExceptionEvent
SEVERE: The CV resize operation did not perform correctly.
WARNING: The HSL Threshold operation did not perform correctly.
java.lang.IllegalArgumentException: HSL Threshold needs a 3-channel input
at edu.wpi.grip.core.operations.composite.HSLThresholdOperation.perform(HSLThresholdOperation.java:68)
SEVERE: The HSL Threshold operation did not perform correctly.
Jan 19, 2016 1:59:46 AM edu.wpi.grip.core.Main start
INFO: SUCCESS! The project is running in headless mode!
What model camera is it?
Just to make sure, it’s plugged into the roboRIO, right?
The model is not on it and the box is long gone. It is a logitech webcam of some type.
Putting the camera on the dashboard works fine, yes it is plugged into the RoboRio.
I updated to Grip 1.1.1 unfortunately I am still unable to create my camera source.
When I plug the webcam into the labtop it works, so I know the camera is compatible and works. I can output the camera to the dashboard, therefore the camera is operation when plugged into the roboRio.
VIDEOIO ERROR: V4L: index 0 is not correct!
Jan 23, 2016 12:33:05 AM edu.wpi.grip.core.Source initializeSafely
java.io.IOException: A problem occurred trying to start the frame grabber for Webcame 0
Do I need to be using a different source when it is plugged into the RIO?
I found my own problem. I should have read the error more carefully.
INFO: Loading file /home/lvuser/project.grip
VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
VIDEOIO ERROR: V4L: setting property #16 is not supported
VIDIOC_STREAMON: Bad file descriptor
Jan 23, 2016 12:57:05 AM edu.wpi.grip.core.Source initializeSafely
The webcam I am using’s pixel format is unsupported by OpenCV
We are getting the same problem with the USB Microsoft LifeCam 3000-HD
I am also trying to get my Microsoft LifeCam 3000-HD to work, but using RoboRealm. After using the FRC_CameraClient module, I get the error “Invalid Jpeg Format”. It works fine when connecting directly to the PC. The only other discussion I have found about this is in this (http://www.roborealm.com/forum/index.php?thread_id=5472) RoboRealm thread:
“It seems that they are using jpeg images but with a couple bytes at the beginning of the stream that indicate size, fps, etc. Its not a standard stream format so we’ll have to create something specific to handle these kinds of streams.”
Perhaps the RoboRio is formatting USB Webcam images specifically for the dashboard? Even if not, it seems to be an issue with the RoboRio, since other webcams are having this same issue. Later in that thread, however, the guy who was having issues said he was able to successfully get the image to come in right, but he doesn’t really explain how.
Edit: This (http://www.chiefdelphi.com/forums/showthread.php?t=134404) thread details how the RoboRio handles USB Webcams. According to it, the images extracted from the webcam is missing a part of the normal JPEG header. While his modified camera viewer may not be useful, he also explains that the Intermediate Vision template will re-encode the images locally.
This defiantly seems to be the problem.
It seems to get closer if you don’t start the camera in the code. It can at least find the camera this way but, it has extraneous data.
VIDEOIO ERROR: V4L/V4L2: VIDIOC_S_CROP
Corrupt JPEG data: 2 extraneous bytes before marker 0xd6
Corrupt JPEG data: 4 extraneous bytes before marker 0xd
How would we go about implementing such a solution?
Just got RoboRealm to pick up the USB Webcam image using the Intermediate Vision example program.
GRIP has loads of potential to be a very powerful tool, I’d like to see if we (being the users of chief delphi) can get it working.
Just curious if anyone has gotten GRIP to work on the RoboRIO using a USB camera. We have it running with the Axis IP camera, but the two MS lifecams we tried both throw that same error.
GRIP on the roboRIO with our USB Lifecam 3000-HD works without camera error but an old Logitech USB camera from the junk box throws those same errors of a bad couple of bytes in each frame. An Axis M1011 IP camera with GRIP running on the driver station PC runs for about a minute then the image freezes. We might guess the setup of the camera isn’t right but the documentation on how to set it up is sparse and there aren’t really very many choices to be made anyway.
We are having severe startup problems but if GRIP can make it past the first few seconds after starting on the roboRIO it runs fine albeit a little slow.
We haven’t tried a USB camera with GRIP on the RoboRio. However, we’ve been going through some contortions to get it running on the Raspberry Pi 2, and that’s also Linux and may share some problems/solutions?
We’re using a Logitech C920 USB, and were initially unable to get it directly working with GRIP running on a RPi2. Not too surprising, since that platform isn’t not officially supported by GRIP. However, there’s an awesome thread on Github with a lot of great community activity getting GRIP onto RPi2.
With the info in that thread we were able to get that USB camera’s feed published as an IP camera using mjpeg-streamer, which GRIP was then able to find and use on the RPi2, running Linux Arm. Might be something to try on the RoboRio?
We haven’t yet verified GRIP is publishing stuff to NetworkTables, we hope to verify that tonight.
Do I still initialize the camera server when trying to use it with grip?
CameraServer server = CameraServer.getInstance();
server.setQuality(50);
server.startAutomaticCapture("cam1");
If you initialize the cameraserver in your robot program GRIP probably won’t be able to access it. Usually only one application can access a camera at a time on Linux.
To get similar functionality as CameraServer, you can use the “Publish Video” operation in GRIP.
I think we are really close to getting this working!
What is setting property #16?
We are getting this error on our deploy:
Jan 27, 2016 1:53:36 AM edu.wpi.grip.core.Main start
Jan 27, 2016 1:53:40 AM edu.wpi.grip.core.Main start
Looking at the OpenCV source code, it seems like it has a lot of video capture properties available for V4L (the Linux video capture API), but most of them are only supported with V4L 2. If you’re using V4L 1 and you try to set any property besides the few that are supported, OpenCV prints an error message
This is completely harmless. Since we don’t do anything to manually configure camera settings in GRIP, any properties that get set are just by OpenCV trying to set up some defaults.
Is the project working otherwise? I noticed you have a SUCCESS message and no exceptions.
Yes! Everything appears to be working. I saw the error an I guess I panicked.
Everything appears to be operational, network tables and all.
Should I be concerned about this error? Everything seems to still work but, maybe.
Jan 28, 2016 3:48:21 AM java.util.logging.LogManager$RootLogger log
Jan 28, 2016 3:48:22 AM java.util.logging.LogManager$RootLogger log
CONFIG: GRIP Version: 1.1.1
Jan 28, 2016 3:48:28 AM edu.wpi.grip.core.Main start
Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent
Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionClearedEvent
Jan 28, 2016 3:48:33 AM edu.wpi.grip.core.Main onExceptionClearedEvent
Jan 28, 2016 3:48:33 AM edu.wpi.grip.core.Main start
It says the image must have a value but, it appears to be getting an image from something.
