Guidance on reading Labview dashboard log files
Hi all,
I’m looking for some guidance on how to accurately read the labview logs that come from a labview dashboard. I have attached a screen shot for example.
I understand most of the chart except for one specific area. The Y-Axis on the right side of the chart has a scale for the PDP current draw. I can’t figure out which line represents the actual current draw being experienced on the robot.
Thanks in advance for the help.
In that picture, none of those lines are PDP current. On the right slide, under groups or plots, you can turn on the power/pdp data.
Using the Plots tab, you can turn on the graphs for individual PDP branch circuits’ current draw. You can also turn on the total PDP current draw, and turn on/off each plot currently on by default. Using the Groups tab, you can turn on/off groups of related graphs.
Also for the record, this is called the Driver Station Log Viewer and it’s a standalone program from both the Driver Station and the dashboard. It’s completely independent of the type of dashboard you’re using.
Thanks for the advice. I now see the PDP options. I didn’t scroll down :slight_smile:
I enabled all of the PDP options on the plots tab, but the values are still showing up as 0. I even exported to excel to confirm and PDP totals were definitely 0.
Is there something I need to enable to see these values?
Here is another screen shot to share what I see.
This happens when the PDP is not connected to roboRio with CAN or firmware is not updated
We have never updated the firmware on these PDPs. That must be the problem as we do have them connected with CAN.
After 5 yrs of doing this, I never knew these log files even existed to help debug robot problems. This is very helpful.
I think its more likely to be a CAN issue, since the factory firmware has supported the PDP reading for several years. What color are the status and comm LEDs on the PDP?
There’s a lot of good information on screensteps, including information about the log viewer: http://wpilib.screenstepslive.com/s/currentCS/m/driver_station/c/86704
