Hi
im tring to use the gyro code . the gyro is working fine but
the p1_x is not getting changing when i move the joystick…
(p1_x moves when i move the y - axis)
can anyone tall me what do i need to change in the code to make it work?
thanks
Hi
thanks
If you’re using my code, it’s very likely that the default code is still commented out in user_routines.c/Process_Data_From_Master_uP(). This is done for safety reasons.
-Kevin
Im calling the Default_routine function from ther and it still not working…
i think the problem is in the serial port routine becuse when im traing to use “FRC SERIAL PORT” code its not working as well
Amiram
Hey Amiram,
מה קורה?
אני ממליץ שתשתמש בבודק שגיאות האיות באנגלית, ככה יהיה להם יותר נוח לקרוא את ההודעות שלך ולעזור לך…
-ליאב
קבוצה מס’ 1578
I was wondering if you could elaborate on this, I did not comment much of what you had commented whaen I added your gyro code to my code from last year, what risks does this present?
James
Uncalibrated joysticks + robot motors. Not a good combination. I think it’s better off disabled by default… less chance of you not realizing it’s got enabled drive motors.
AMIRAM, It sounds like you either have a bad joystick, or someone was playing with the Disable switches on the OI. I suggest trying another joystick, or looking at those switches.
I dont see how this being uncommented is any different then the default code, I changed Kevins variable i in order to avoid haing to variables with the same name. Could you please elaborate, I dont see how this would enable any motors that woulnt be enabledin the default code.
Thanks
James
Ignore the rest of my post other then this:
The rest had nothing to do with your problem.
Oh alright, I see what you meant in you origianal post sorry about that
Yep. I don’t want people loading my code on their 'bot with the possibility that some motor is going to take off on them.
-Kevin
Hi
Im using the FRC 2006 Default_code when i add kevin’s serial port code the FRC is not geting the right Data from the OI … :rolleyes:
can u tell me who to edit the “Serial_Char_Callback” function to recive Data
from the ttl port
tried to do it with kevin’s serial code and it didnt work
thanks
