gyro code
we used a gyro to balance our arms but the gyro would return to center after about a second or two so we made a pendulum.
here is our code before we took it out. you may need to tweak some variables.
If p3_sw_top = 1 then
If p3_y > 127 then
If balancing_motor_limit_forward = 0 then balancing_motor = p3_y
else
if p3_y < 127 then
	if balancing_motor_limit_reverse = 0 then balancing_motor = p3_y
endif
endif
else
If state = 0 then
balancing_motor = 183
	If balancing_motor_limit_forward = 1 then balancing_motor = 127
	If gyro => 180 then state = 1
else
	If state = 1 then
		balancing_motor = 63
		If balancing_motor_limit_reverse = 1 then balancing_motor = 127
		counter = counter + 1
		If counter => 30 then
			state = 2
		endif
	else
		If state = 2 then balancing_motor = 127
	endif
endif
endif
Are you asking a question, or offering your code for others to use?
i was offering code to other to use. it was supposed to be a reply but i clicked the wrong button and didn’t realize.
