I have been playing around with trying to make a minibot smaller than Shrinky Dink, with the constraints of this game. At the same time if my team ever wanted to make this thing, i was trying to make it as cheap as possible given my teams manufacturing ability. I have been tinkering on this for a while, showing it off through its CAD in Weekly Wins and Team A vs. Team B.
With the intro none of you probably needed, I present Wingnut:
Board Stages:
Segmented into 4 distinct boards (the last two are essentially the same). The first one is mounted using 4 screws, and also holds the bumper, and arm bases onto it. The boards have on them respectively:
Bottom 1st Stage: 2x Sparkmax for drive
Top 1st Stage: CTREPDP
2nd Stage: Battery (contrained by 2 battery straps)
3rd/4th Stage: Switch, Radio, RPM, Rio, RSL
Battery swap procedure:
Drop the Shooter mechanism to extended position
Unscrew the 4 10-32 screws attaching the 3rd Stage
Swing the 3rd stage opposite the Shooter mechanism
Unplug battery
Undo the battery straps
Bumpers
Taking advantage of the 1/4" allowance for hard parts, uses 1/4" steel brackets to add weight and strength. I was inspired by 1100’s bumper mounts, so this bumper drops out the bottom and is mounted using 4 bolts into churro.
Yes, they are skid plates! I couldn’t fit omni wheels with where I wanted the wire passthrough holes to be for the Sparkmaxes. I’m sure I could have made it work, but the skid plates seemed the better idea at the time.
I was lazy and just did a Replicate function on all the holes there, so no, they do not. To keep individual part count down, I just had the holes mirrored with different attachment points.
This was a complete rush job of a CAD, and I already knew that fitting the 4-bar shooter/amp mechanism was going to be a long shot based off previous CAD testing, so I just didn’t even bother trying to fit it.
Also, I dont think I can get an amp bar into the original unless it is actually built, I would need to do a couple of bent-polycarb things to act as an arm because the thing is too short and not enough space is available to make the amp bar be a rigid body and also fit.
It would be cool to see the motor on the amp mechanism moved towards the base, and have the mechanism run off of a belt. Maybe even move to a cim class motor to eliminate the gearbox.
