HAL: CAN Receive has Timed Out errors w/ Rev PDH
I’m seeing a lot of the following errors:
Error at frc.robot.Main.main(Main.java:23): HAL: CAN Receive has Timed Out
edu.wpi.first.hal.PowerDistributionJNI.getTotalCurrent(Native Method)
edu.wpi.first.wpilibj.PowerDistribution.lambda$initSendable$2(PowerDistribution.java:211)
edu.wpi.first.wpilibj.smartdashboard.SendableBuilderImpl.lambda$addDoubleProperty$4(SendableBuilderImpl.java:260)
edu.wpi.first.wpilibj.smartdashboard.SendableBuilderImpl.update(SendableBuilderImpl.java:104)
edu.wpi.first.wpilibj.livewindow.LiveWindow.lambda$updateValues$3(LiveWindow.java:191)
edu.wpi.first.util.sendable.SendableRegistry.foreachLiveWindow(SendableRegistry.java:491)
edu.wpi.first.wpilibj.livewindow.LiveWindow.updateValues(LiveWindow.java:147)
edu.wpi.first.wpilibj.IterativeRobotBase.loopFunc(IterativeRobotBase.java:333)
edu.wpi.first.wpilibj.TimedRobot.startCompetition(TimedRobot.java:131)
edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:373)
edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:463)
I found this thread about similar errors with the PDH HAL: CAN Receive has Timed Out
This might be a side effect of high CAN traffic. It bounces between 60-100%
Considering disabling Livewindow
