CODE:
import edu.wpi.first.wpilibj.controller.PIDController;
import org.junit.Assert;
import org.junit.Before;
import org.junit.Test;
public class Yes {
@Before
public void setup() {
PIDController pidController = new PIDController(0.23, 0, 0, 1);
@Test
public void yes() {
Assert.assertEquals(0, 0, 0);
ERROR:
java.io.IOException: wpiHaljni could not be loaded from path or an embedded resource.
attempted to load for platform /windows/x86-64/
Last Load Error:
no wpiHaljni in java.library.path: [C:\Users\saarz.jdks\corretto-11.0.11\bin, C:\WINDOWS\Sun\Java\bin, C:\WINDOWS\system32, C:\WINDOWS, C:\Python39\Scripts, C:\Python39, C:\Program Files (x86)\Razer\ChromaBroadcast\bin, C:\Program Files\Razer\ChromaBroadcast\bin, C:\Program Files (x86)\Common Files\Oracle\Java\javapath, C:\Windows\system32, C:\Windows, C:\Windows\System32\Wbem, C:\Windows\System32\WindowsPowerShell\v1.0, C:\Windows\System32\OpenSSH, C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common, C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR, C:\WINDOWS\system32, C:\WINDOWS, C:\WINDOWS\System32\Wbem, C:\WINDOWS\System32\WindowsPowerShell\v1.0, C:\WINDOWS\System32\OpenSSH, C:\Program Files\Git\cmd, C:\Users\saarz\AppData\Local\Microsoft\WindowsApps, C:\Users\saarz\AppData\Local\gitkraken\bin, C:\Program Files\dotnet, C:\Program Files\nodejs, C:\ProgramData\chocolatey\bin, C:\Users\saarz\AppData\Local\Microsoft\WindowsApps, C:\Users\saarz\AppData\Local\gitkraken\bin, C:\Users\saarz.dotnet\tools, C:\Users\saarz\AppData\Roaming\npm, C:\Program Files\nodejs, ., C:\Users\saarz\AppData\Local\Programs\Microsoft VS Code\bin, .]
A common cause of this error is missing the C++ runtime.
Download the latest at https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads
at edu.wpi.first.wpiutil.RuntimeLoader.loadLibrary(RuntimeLoader.java:79)
at edu.wpi.first.hal.JNIWrapper.<clinit>(JNIWrapper.java:34)
at edu.wpi.first.wpilibj.controller.PIDController.<init>(PIDController.java:92)
at Yes.setup(Yes.java:13)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.junit.runner.JUnitCore.run(JUnitCore.java:137)
at com.intellij.junit4.JUnit4IdeaTestRunner.startRunnerWithArgs(JUnit4IdeaTestRunner.java:69)
at com.intellij.rt.junit.IdeaTestRunner$Repeater.startRunnerWithArgs(IdeaTestRunner.java:33)
at com.intellij.rt.junit.JUnitStarter.prepareStreamsAndStart(JUnitStarter.java:235)
at com.intellij.rt.junit.JUnitStarter.main(JUnitStarter.java:54)
Process finished with exit code 1
Configuration is with JUnit
