Q 228 Motor Controller (Talon/Victor) pigtail replacement.
Are we permitted to change-out the short pigtail leads on motor controller. Effectively swapping it out with identical silicone wire (same color and gauge) in order to increase its length.
Answer
No, modifications to these devices are prohibited per R73. De-soldering the wire pigtails is not one of the exceptions listed in items A-O of R73.
I would have thought this fell under R73 L and/or M, and further been usable in future years assuming that R15 D continues with little or no change. Anyone else find this strange, or expected?
R73
- L. Integral wires on motor controllers may be cut, stripped, and/or connectorized.
- M. Devices may be repaired, provided the performance and specifications of the device after the repair are identical to those before the repair.
R15. Physical ROBOT elements created before Kickoff are not permitted. Exceptions are:
- A. OPERATOR CONSOLE,
- B. BUMPERS (a protective assembly designed to attach to the exterior of the ROBOT and constructed as specified in the BUMPER Rules section),
- C. battery assemblies per R5-B,
- D. FABRICATED ITEMS consisting of one COTS electrical device (e.g. a motor or motor controller) and attached COMPONENTS associated with any of the following modifications:
- i. wires modified to facilitate connection to a ROBOT (including removal of existing connectors)
- ii. connectors and any materials to secure and insulate those connectors added
- iii. motor shafts modified and/or gears, pulleys, or sprockets added
- iv. motors modified with a filtering capacitor as described in the Blue Box below R63
