Hi, I was following the wpi screensteps for trajectory following code and when I got to the position update I got an error message even though I was following wpi’s steps
(my code)
(screensteps code)
can someone please help me with this?
(my code)
(screensteps code)
I’m presuming that you’re following this: Mecanum Drive Odometry — FIRST Robotics Competition documentation
Does getHeading() return a Rotation2d? Does getSpeed() return MecanumDriveWheelSpeeds? That’s what the MecanumDriveOdopmetry update method takes.
If that’s not it, we’ll need more context. Which tutorial are you following? What is the error message? Need more context for the code.
( it starts right when he talks about the position update)
and the error message is “The method update(Rotation2d, double, double) in the type DifferentialDriveOdometry is not applicable for the arguments (Rotation2d, DifferentialDriveWheelSpeeds)”
There was an update to the update
method before it was released to the public. The update removed the overload that accepted a DifferentialDriveWheelSpeeds
objects. Now in order to call the update
method you need to provide the 2 wheel distances instead of wheel speeds. For an example of how to do this, take a look at this page of the FRC Documentation.
does the encoder position counts as distance?
No. The number passed into the update
method must be in a distance in meters.
Oops, I should probably add a note to the description of that video saying that the method I used was removed (by me, ironically).
But yeah, as Austin mentioned, the API changes a lot during the beta period, but it should be solid now and the latest documentation should reflect that.
Edit: Description has now been updated.
