Help a rookie please
Hey, i’ve never used pneumatics and now i have some problems with it, beeing my first time.
What i need:
Have a cylinder that can move my gripper to 3 different positions.
Poisiton A: Grab the Ball
Position B: lift the ball up to the arm (so we can get in the 80’’ length limit while lifting the ball.
Positiion C: Gripper touches the arm, only needed in start of the match in order to get in the initial sizes of the game.
Is there any way i can easily do this?
Please remember you are speaking to a pneumatic noob, so i will probably need both an explanation on how to mechanicly do it and how to program it.
i’ve read some threads that say that i should connect 2 selenoids together, but i did not really understand how i am going to control it.
PS, the cylinder there will basicly need to make te following move:
start of match from poisition C to A, and the rest of the match just switch between positions A and B, mechanicly the order of the positions is C-B-A.
Thanks =]
Easiest way: 2 cylinders, end-to-end.
Second easiest way: 2 solenoids. One is connected to the other’s exhaust port. This will be a “soft” middle position.
I’ll let someone else explain how to program it. Partly because I’m not exactly sure how.
See THIS Thread. There is no need for two solenoid valves, ever, to make a piston stop mid-stroke. This is done all the time in industry, and of course there is a simple solution.
Just keep in mind that air is compressible. That means, if the load on your piston changes, it will move from that mid-point position.
Don
