Hi!
Hope everyone is doing fine so far this season.
We ran into some problems attaching the falcon motor to the Versaplanetary gear.
We used the CIM adapter with the falcon VP Press On Motor Coupler and the shaft was too long so the falcon Collided with the versa instead of reaching the end.
If the you’re using the long falcon shaft then you could just figure out what you need to remove from it’s length to get adequate clearance. Then just go ahead and shorten it. However it would be ideal if you put an existing short shaft.
If you currently have a short shaft installed on the falcon then something else is wrong like you’re missing a stage/adaptor somewhere in between.
If you’re unsure of what shaft you have measure it’s length and see which shaft it corresponds to.
The little metal shim intended to mimic the CIM spigot will fit in the the versa end block and look like it belongs there. It will hit the coupler and give about 1MM gap. Don’t ask how I know.
