HELP! FRC Bumper Fabric Mistake!
Hey! We recently marked the wrong side of the bumper fabric with pencil and are trying desperately to get the pencil markings out. We’ve tried water, and isopropyl alcohol. What suggestions do you have to fix this problem?
Either Staedtler plastic eraser or Mr. Clean Magic Eraser should work.
We’ve tried the rubber eraser and that doesn’t do anything, will try Mr.Clean
To be specific, did you try a Staedtler plastic eraser? Or a random rubber eraser? Staedtler is pretty awesome…
What kind of pencil was used?
I’ve never had a problem with pencils on fabric. That’s a new one on me. Since FRC bumpers are made of a nylon fabric, it shouldn’t be hard to remove the markings with a soft art eraser or sponge with soap. You can always try a small dab of diluted bleach. Bleach might change the color, but you can always do the marker trick.
You can try silicone based surface cleaners. But avoid excessive use, excessive use may cause whitening of the fabric.
How bad are the pencil marks? (pics?)
