Hello CD,
I am trying to get an old 8 slot c-rio working. When I went to up load it only got this far:
ant -f C:\Users\Braeden\Documents\NetBeansProjects\MyRobot deploy run
clean:
Deleting directory C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build
Created dir: C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build
Created dir: C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\classes
[crio-compile] ./src, C:/Users/Braeden/sunspotfrcsdk\lib\wpilibj.jar;C:/Users/Braeden/sunspotfrcsdk\lib
etworktables-crio.jar, C:/Users/Braeden/sunspotfrcsdk\lib\squawk.jar -> ./build/classes
Compiling 10 source files to C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\classes
warning: [options] source value 1.3 is obsolete and will be removed in a future release
warning: [options] target value 1.2 is obsolete and will be removed in a future release
warning: [options] To suppress warnings about obsolete options, use -Xlint:-options.
3 warnings
compile:
preverify:
Created dir: C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\preverify
Created dir: C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\preverify.raw.util
[crio-preverify] ./build/classes, , C:/Users/Braeden/sunspotfrcsdk\lib\wpilibj.jar;C:/Users/Braeden/sunspotfrcsdk\lib
etworktables-crio.jar, C:/Users/Braeden/sunspotfrcsdk\lib\squawk.jar -> ./build/preverify
Expanding: C:\Users\Braeden\sunspotfrcsdk\lib\wpilibj.jar into C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\preverify
etworktables-crio.jar into C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\preverify
jar:
[crio-jar] ./build/preverify, ./resources -> ./build/app.jar
Building jar: C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\app.jar
suite:
Created dir: C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\suite
[crio-suite] ./build/app.jar -> ./build/suite/image
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] …]
Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
Excluding compile: com.sun.squawk.Method::getParameterTypes
[Including resource: META-INF/MANIFEST.MF]
[Including resource: META-INF/maven/edu.wpi.first.wpilib.networktables.java/NetworkTablesAzalea/pom.properties]
[Including resource: META-INF/maven/edu.wpi.first.wpilib.networktables.java/NetworkTablesAzalea/pom.xml]
Romizer processed 397 classes and generated 4 files.
Expanding: C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\app.jar into C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\suite
Moving 1 file to C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\build\suite
Deleting: C:\Users\Braeden\Documents\NetBeansProjects\MyRobot\image.suite.api
deploy:
[crio-configure] Configuration files not included in this version of the sdk
[crio-configure] Checking that crio is configured for Java
Host OS: Windows 10 10.0, 10.0
Host JVM: Java HotSpot™ 64-Bit Server VM 25.171-b11
Target IP: 10.34.61.2
Network interfaces on host:
Realtek PCIe GBE Family Controller: address: 10.34.61.77 netmask: 255.255.255.0 <— on robot’s subnet
Connecting FTP @10.34.61.2
Can someone please help me?
thank you
