[HELP] How to Make a Servo Work
It’s plugged into the RoboRio in PWM port 2. There’s a global variable:
Servo servo = new Servo(2);
In teleopPeriodic, this code does not work to extend the actuator:
servo.set(1.0);
How do you control a servo with code?
PLEASE HELP!
We really need to know this soon!
Have you tried values other than just 1.0? Perhaps you can try .5 and see if you get any result. As well, make sure that you don’t have the cable backwards.
Doing that didn’t work.
Can you post your whole code and a picture of your wiring. That will help us diagnose your problem.
We don’t have any wiring. The servo is plugged directly into RoboRio port 2.
Here’s the code:
/* Copyright (c) 2017-2018 FIRST. All Rights Reserved.                        */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package frc.robot;
import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.SPI;
import com.kauailabs.navx.frc.AHRS;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
import edu.wpi.first.wpilibj.PWMTalonSRX;
import edu.wpi.first.wpilibj.Spark;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import edu.wpi.first.wpilibj.Servo;
import edu.wpi.cscore.UsbCamera;
import edu.wpi.first.cameraserver.*;
  // Link robot to code
  DifferentialDrive robotDrive = new DifferentialDrive(new Spark(0), new Spark(1));
  // Link controller to code
  Joystick controller = new Joystick(0);
  JoystickButton LTrigger = new JoystickButton(controller, 2);
  JoystickButton RTrigger = new JoystickButton(controller, 3);
  JoystickButton A = new JoystickButton(controller, 6);
  JoystickButton B = new JoystickButton(controller, 7);
  JoystickButton Y = new JoystickButton(controller, 9);
  // Link other stuff to code
  PWMTalonSRX talon = new PWMTalonSRX(3);
  AHRS gyro;
  // Control variables
  double maxSpd = 0.65;
  boolean lowerLance = true;
  @Override
  public void robotInit()
    // Camera
    CameraServer.getInstance().startAutomaticCapture();
    // Gyroscope
    gyro = new AHRS(SPI.Port.kMXP);
    // Talon SRX
    talon.enableDeadbandElimination(true);
  @Override
  public void robotPeriodic() {
  @Override
    gyro.reset();
  @Override
    /*double angle = 180.0;
    if (gyro.getAngle() < angle) {
      robotDrive.arcadeDrive(0.0, -0.5);
    teleopPeriodic();
  @Override
  public void teleopPeriodic()
    // Get controller inputs
    double y = -controller.getY();
    double x = controller.getX();
    double gear = controller.getPOV();
    // Speed gears for robot
    if (gear == 0) {
      maxSpd = 0.8;
    else if (gear == 270 || gear == 90) {
      maxSpd = 0.7;
    else if (gear == 180) {
      maxSpd = 0.65;
    // Limit max speed
    if (y > maxSpd) {
      y = maxSpd;
    else if (y < -maxSpd) {
      y = -maxSpd;
    if (x > maxSpd) {
      x = maxSpd;
    else if (x < -maxSpd) {
      x = -maxSpd;
    // Toggle the lance's position
    if (Y.get())
      lowerLance = !lowerLance;
    // Lower the lance
    if (lowerLance && servo.get() != 0.0)
      servo.set(0.0);
    else if (!lowerLance && servo.get() != 1.0)
      servo.set(1.0);
    // Control lift
    if (controller.getRawAxis(5) < -0.05 || controller.getRawAxis(5) > 0.05)
      talon.set(controller.getRawAxis(5));
    else
      talon.set(0.0);
    // Send robot angle to dashboard
    SmartDashboard.putNumber("Angle", Math.round((float)gyro.getAngle()));
    // Drive robot
    robotDrive.arcadeDrive(y, x);
  @Override
  public void testPeriodic() {
set() is a different function from setAngle(). It ranges from 0.0 to 1.0 and is supposed to set the position of the servo.
Just for fun, can you post a picture showing the servo PWM cable in the roboRIO. And a picture of the servo itself.
Trust me, it’s in correctly. Do you know what a jumper is or if we need one?
The servo is a actuator, and it extended fully the first time we plugged it in and ran the robot, before we even had the code to control it. Now it simply does nothing.
Try simply calling servo.set(1) (or any number) in teleop, instead of trying to put it in a button control loop, just to see if your button programming is working as expected
I already tried that. :sob:
What color is the power LED on your roborio?
The RoboRio is on, as we can drive our robot.
That’s not what he’s asking. If there’s a short on one of the roboRIO power rails, the power light will turn from green to red. And that would make your servo not work.
In the future if you want help, I suggest you answer the questions and provide us the information we’re asking. Otherwise, you’re wasting our time trying to help you.
