[HELP] Motors Becoming Sentient
I’ve seen metal shavings inside the PWM connectors short the signal wire. This could be intermittent and only happen if the wires is pushed in one direction. In addition to what everyone else said, you should check to make sure there are no metal shavings inside the PWM port.
The solution was recalibrating the Sparks and tightening our wire connections. Thanks for the advice, everybody!
