Currently we’re experiencing an issue with our code where we’re getting the rio log below with errors and we have no clue whats wrong. If anyone could tell us our problem it’d be a big help, we know it’s something regarding the SwerveSubsystem.java file but we’re lost on the madder
GitHub:
BR8817/2025_Swerve: Our 2025 test code for our swerve originally using our 2024 season code
RIO LOG
********** Robot program starting **********
NT: Listening on NT3 port 1735, NT4 port 5810
NT: Got a NT4 connection from 10.88.17.180 port 64771
NT: CONNECTED NT4 client ‘shuffleboard@1’ (from 10.88.17.180:64771)
CS: USB Camera 0: Attempting to connect to USB camera on /dev/video0
NT: Got a NT4 connection from 10.88.17.180 port 64819
NT: CONNECTED NT4 client ‘shuffleboard@1’ (from 10.88.17.180:64819)
“conversionFactors”: {
“angle”: {“factor”: 28.125 },
“drive”: {“factor”: 0.047286787200699704 }
[CAN SPARK] IDs: 8, Received parameter invalid error parameter id 113
Unhandled exception: java.lang.RuntimeException: java.lang.IllegalStateException: Received parameter invalid error parameter id
Error at frc.robot.subsystems.swervedrive.SwerveSubsystem.(SwerveSubsystem.java:109): Unhandled exception: java.lang.RuntimeException: java.lang.IllegalStateException: Received parameter invalid error parameter id
at frc.robot.RobotContainer.(RobotContainer.java:63)
at frc.robot.Robot.robotInit(Robot.java:55)
at edu.wpi.first.wpilibj.TimedRobot.startCompetition(TimedRobot.java:107)
at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:419)
at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:510)
at frc.robot.Main.main(Main.java:27)
The robot program quit unexpectedly. This is usually due to a code error.
The above stacktrace can help determine where the error occurred.
See Reading Stacktraces — FIRST Robotics Competition documentation for more information.
from: edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:433)
Warning at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:433): The robot program quit unexpectedly. This is usually due to a code error.
The startCompetition() method (or methods called by it) should have handled the exception above.
Error at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:440): The startCompetition() method (or methods called by it) should have handled the exception above.
