Help On 360 servo
Hello I’m part of a rookie team and were getting used to all the programming and i decided to use a 360 servo that is controlled by the joystick’s x-axis but when i put it on tele-up all it does is spin in circles. Im guessing it has something to do with the bounds so I’m guessing i have use the setBOunds() method but i have no idea on what to make the parameters like the deadmax, max, center act. Thank you.
Can you say more about the 360 servo? Are you referring to the Vex motor supplied in the kit of parts?
Brad
It is a tetrix 360 servo
we use the servo class
do you mean these?
if so, we use the servo class
http://www.wbrobotics.com/javadoc/edu/wpi/first/wpilibj/Servo.html
and you just use the pwm cable for it.
