So I am currently working on a very simple graphing of jaci’s pathfinder trajectories. Here is the deal. I keep getting the “Exception in thread “main” java.lang.UnsatisfiedLinkError: no pathfinderjava in java.library.path” exception. I have the .jar file and the .so file because I am not running GradleRIO. I don’t know if the problem is the fact that it is not the robot and the native libraries only work on the robot. I’m so confused and I have dived to deep into this. I just want to have my code work. This is it if you need it.
package Main;
import java.awt.BorderLayout;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.io.File;
import javax.swing.JButton;
import javax.swing.JComboBox;
import javax.swing.JFrame;
import javax.swing.JPanel;
import org.jfree.chart.ChartFactory;
import org.jfree.chart.ChartPanel;
import org.jfree.chart.JFreeChart;
import org.jfree.chart.event.ChartChangeEvent;
import org.jfree.chart.event.ChartChangeListener;
import org.jfree.data.xy.XYSeries;
import org.jfree.data.xy.XYSeriesCollection;
import org.jfree.ui.RectangleInsets;
public class GraphTrajectory {
static double prevTime;
static double originalTime = System.currentTimeMillis();
static boolean run = true;
static boolean disabled = false;
public static void main(String args]) {
final TrajectorySetup trajectorySetup = new TrajectorySetup();
trajectorySetup.setup();
//create and configure the window
JFrame window = new JFrame();
window.setTitle("Trajectory GUI");
window.setSize(1200,1000);
window.isResizable();
window.setLayout(new BorderLayout());
window.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
final JButton button = new JButton("Load");
window.add(button,BorderLayout.NORTH);
//create xy line graph
final XYSeries leftSeries = new XYSeries("Left To Right Movement");
final XYSeries rightSeries = new XYSeries("Forward to Backward Movement");
XYSeriesCollection dataset = new XYSeriesCollection(leftSeries);
dataset.addSeries(rightSeries);
JFreeChart chart = ChartFactory.createXYLineChart("X", "Y", "Percent Input", dataset);
window.add(new ChartPanel(chart),BorderLayout.CENTER);
button.addActionListener(new ActionListener() {
@Override
public void actionPerformed(ActionEvent e) {
if(button.getText().equals("Load")) {
button.setText("End");
run = true;
disabled = false;
Thread thread = new Thread() {
@Override public void run() {
while(run) {
if(System.currentTimeMillis() - prevTime >= 0.020) {
try {
leftSeries.add(trajectorySetup.leftXTrajectory(), trajectorySetup.leftYTrajectory());
rightSeries.add(trajectorySetup.rightXTrajectory(), trajectorySetup.rightYTrajectory());
prevTime = System.currentTimeMillis();
}catch(Exception e) {}
thread.start();
}else if(button.getText().equals("End")){
Thread starterThread = new Thread() {
button.setText("Load");
run = false;
disabled = true;
starterThread.start();
//show the window
window.setVisible(true);
button.doClick();
package Main;
import jaci.pathfinder.Pathfinder;
import jaci.pathfinder.Trajectory;
import jaci.pathfinder.Waypoint;
import jaci.pathfinder.Trajectory.FitMethod;
import jaci.pathfinder.modifiers.TankModifier;
public class TrajectorySetup {
double wheelBase_width = 30;
Trajectory left, right;
Trajectory.Segment segLeft, segRight;
public TrajectorySetup() {
public void setup() {
Waypoint] points = new Waypoint] {
new Waypoint(0,0,90),
new Waypoint(0,55,90)
Trajectory.Config config = new Trajectory.Config(FitMethod.HERMITE_CUBIC, 10000, 0.020, 4, 1, 0.5);
Trajectory trajectory = Pathfinder.generate(points, config);
TankModifier modifier = new TankModifier(trajectory);
modifier.modify(wheelBase_width);
left = modifier.getLeftTrajectory();
right = modifier.getRightTrajectory();
public double leftXTrajectory() {
for (int i = 0; i < left.length(); i++) {
segLeft = left.get(i);
return segLeft.x;
public double leftYTrajectory() {
return segLeft.y;
public double rightXTrajectory() {
for (int i = 0; i < right.length(); i++) {
segRight = right.get(i);
return segRight.x;
public double rightYTrajectory() {
return segRight.y;
I have referenced Pathfinder and my other two jar that I need to run the graph, which those two run fine and I don’t have any problems with them. I just can not run anything on my computer with the pathfinder.
