Hi,
I need to program one piston. My compressor works.
Could I see a picture your labview code for the solenoids? Do you have it so that when you hit a button on the controller that the piston goes out, and the goes back in when you hit another button?
Something you might do it look in the examples and see the compressor w/ solenoid. That might help
I can’t seem to find it. Can you find a link?
If I remember correctly, you’ll want to open your code project and then click the “Help” drop down box in the toolbar. There should be an option named “Find LabVIEW Examples…” Once you click on that, you can search for examples with the context menu that pops up.
