Help Reading Network Tables
Hi,
I was trying to read a specific value from the robot while following this - https://wpilib.screenstepslive.com/s...client-pc-side
But when I was doing so I noticed a ton of stuff on how the NetworkTables behaved had changed.
We are using Java.
Is there a simple way to get the same result as the screensteps tutorial using the 2018 API?
An example would be amazing.
Regards
Gagan Bhat
I’ve been wondering about the same thing, getting (in my case, the limelight) table from NetworkTables… Will definitely be following this thread
First, I want to point out that the old API still works. But if you want to switch over to the new API, here’s a simple Java client example:
package networktablesdesktopclient;
import edu.wpi.first.networktables.NetworkTable;
import edu.wpi.first.networktables.NetworkTableEntry;
import edu.wpi.first.networktables.NetworkTableInstance;
public class NetworkTablesDesktopClient {
  public static void main(String] args) {
    new NetworkTablesDesktopClient().run();
  public void run() {
    NetworkTableInstance inst = NetworkTableInstance.getDefault();
    NetworkTable table = inst.getTable("datatable");
    NetworkTableEntry xEntry = table.getEntry("x");
    NetworkTableEntry yEntry = table.getEntry("y");
    inst.startClientTeam(TEAM);  // where TEAM=190, 294, etc, or use inst.startClient("hostname") or similar
    inst.startDSClient();  // recommended if running on DS computer; this gets the robot IP from the DS
    while (true) {
      try {
        Thread.sleep(1000);
      } catch (InterruptedException ex) {
        System.out.println("interrupted");
        return;
      double x = xEntry.getDouble(0.0);
      doubly y = yEntry.getDouble(0.0);
      System.out.println("X: " + x + " Y: " + y);
If you’re looking to get values just inside of a subsystem etc. read through this. I made this for grabbing values from the limelight/changing values, so I hope it can be of use and help explain some stuff.
I created an application using Peter’s code above but when it runs I get the error below. I made two changes to the code to add my team number and fix the “doubly” typo near the end. I referenced the following library which resolves the NetworkTable references but I assume this is my mistake.
C:\Users\kingb\wpilib\java\current\lib
tcore.jar
Don’t I need the client (PC) side version of this library? I believe the one above is for the RoboRIO.
Assuming this is my problem, does anyone know where the correct library/jar is located?
Thanks
Exception in thread “main” java.lang.NoClassDefFoundError: edu/wpi/first/wpiutil/RuntimeDetector
at edu.wpi.first.networktables.NetworkTablesJNI.<clinit>(NetworkTablesJNI.java:27)
at edu.wpi.first.networktables.NetworkTableInstance.getDefault(NetworkTableInstance.java:88)
at networktablesdesktopclient.NetworkTablesDesktopClient.run(NetworkTablesDesktopClient.java:13)
at networktablesdesktopclient.NetworkTablesDesktopClient.main(NetworkTablesDesktopClient.java:9)
Caused by: java.lang.ClassNotFoundException: edu.wpi.first.wpiutil.RuntimeDetector
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
… 4 more
That’s correct, the jar in the plugins is for the RoboRIO, and you were also missing the wpiutil jar. You’ll need the following 3 jar files for desktop use:
http://first.wpi.edu/FRC/roborio/maven/release/edu/wpi/first/ntcore/ntcore-java/4.0.0/ntcore-java-4.0.0.jar (ntcore java files)
http://first.wpi.edu/FRC/roborio/maven/release/edu/wpi/first/ntcore/ntcore-jni/4.0.0/ntcore-jni-4.0.0-all.jar (ntcore native libs for all desktop platforms)
http://first.wpi.edu/FRC/roborio/maven/release/edu/wpi/first/wpiutil/wpiutil-java/3.0.0/wpiutil-java-3.0.0.jar (wpiutil java files)
That fixed it, Thanks
