Recently i have been testing out simulation and the IO structure with advantage kit and advantage scope and I am met with this problem where my swerve can move normally in the simulation until i have an input on the right x axis which controls the rotation of the entire chassis. After there is an input on the right x axis the swerve starts to spin no matter what I input, if i drive input to drive forward it will just spin and start going faster and faster. I feel like the problem is with the yaw of my pose estimator not updating properly but I am not sure. Below is the code attached
Check that you’re not crossing radians and degrees. It can be tricky!
I had a thing like this happen to me but the issue was I was using the wrong controller if your using the command xbox controller for you controller input in code and use a playstation controller to try to drive it will cause the robot to spin and presumably vice versa
I had a similar problem like this when writing our team’s swerve code. I did something similar to this to fix it:
if(!record.gyroYaw.isPresent()){ // gyro not available in sim
Twist2d twist = kinematics.toTwist2d(lastModulePosition,record.modulePositions());
Logger.recordOutput("RobotSTate/Odometry/lastModulePosition", lastModulePosition);
Logger.recordOutput("RobotSTate/Odometry/record Module Pos", record.modulePositions());
Logger.recordOutput("RobotSTate/Odometry/Twist", twist);
double angularRate = twist.dtheta;
lastGyroYaw = lastGyroYaw.rotateBy(Rotation2d.fromRadians(
!Double.isNaN(angularRate)
? angularRate * 0.02 // multiply rate by period
: 0);
} else{
lastGyroYaw = record.gyroYaw.get();
I tried this but there it still spins like crazy. The gyro yaw changes normally when i rotate the swerve, but after that if I try to move the swerve forward it also changes the gyro yaw.
I use xbox controller for both the code and to drive it.
is it possible that it is something like the swerve modules don’t point forward when I drive forward but instead stay in their current orientation. so when I try to drive forward it will move the wheels but the angle of the wheels don’t change.
