Hello. I’m new to FRC, and as a mentor for Team SPORK - 3196. I am attempting a lesson in using AprilTags using Romi’s with Pi camera’s, with 3d PhotonVision calibrated AprilTag pipeline.
I am able to target an AprilTag in 3d on Photonlib (10.0.0.2:5800). However, I am unable to use the target data from the Photon Camera.
Ask: How does one use PhotonCamera data of a targeted AprilTag using Romi Timed Robot template?
Code sample below:
private static final boolean runCameraTest = true;
private static final String kDefaultAuto = “Default”;
private static final String kCustomAuto = “My Auto”;
private String m_autoSelected;
private final SendableChooser m_chooser = new SendableChooser<>();
private final RomiDrivetrain m_drivetrain = new RomiDrivetrain();
// Constants such as camera and target height stored. Change per robot and goal!
final double CAMERA_HEIGHT_METERS = Units.inchesToMeters(24);
final double TARGET_HEIGHT_METERS = Units.feetToMeters(5);
// Angle between horizontal and the camera.
final double CAMERA_PITCH_RADIANS = Units.degreesToRadians(0);
// How far from the target we want to be
final double GOAL_RANGE_METERS = Units.feetToMeters(3);
// Change this to match the name of your camera
//PhotonCamera camera = new PhotonCamera("phtonvision");
PhotonCamera camera = new PhotonCamera("photonvision");
// PID constants should be tuned per robot
final double LINEAR_P = 0.1;
final double LINEAR_D = 0.0;
PIDController forwardController = new PIDController(LINEAR_P, 0, LINEAR_D);
final double ANGULAR_P = 0.1;
final double ANGULAR_D = 0.0;
PIDController turnController = new PIDController(ANGULAR_P, 0, ANGULAR_D);
//XboxController xboxController = new XboxController(0);
PS4Controller ps4Controller = new PS4Controller(1);
- This function is run when the robot is first started up and should be used for any
- initialization code.
@Override
public void robotInit() {
m_chooser.setDefaultOption(“Default Auto”, kDefaultAuto);
m_chooser.addOption(“My Auto”, kCustomAuto);
PhotonCamera.setVersionCheckEnabled(false);
//Get the default instance of NetworkTables that was created automatically
//when your program starts
camera.setDriverMode(false);
This function is called every robot packet, no matter the mode. Use this for items like
diagnostics that you want ran during disabled, autonomous, teleoperated and test.
This runs after the mode specific periodic functions, but before LiveWindow and
SmartDashboard integrated updating.
@Override
public void robotPeriodic() {
double forwardSpeed;
double rotationSpeed;forwardSpeed = -ps4Controller.getRightY();
//if (xboxController.getAButton()) {
if (ps4Controller.getCrossButton() && runCameraTest) {
// Vision-alignment mode
// Query the latest result from PhotonVision
var result = camera.getLatestResult();if (result.hasTargets()) { // Calculate angular turn power // -1.0 required to ensure positive PID controller effort _increases_ yaw rotationSpeed = -turnController.calculate(result.getBestTarget().getYaw(), 0); } else { // If we have no targets, stay still. rotationSpeed = 0; }
} else {
// Manual Driver Mode
//rotationSpeed = xboxController.getLeftX();
rotationSpeed = ps4Controller.getLeftX();
}// Use our forward/turn speeds to control the drivetrain
m_drivetrain.arcadeDrive(forwardSpeed, rotationSpeed);//let’s follow the health of the romi
SmartDashboard.putNumber("Drivetrain Left Enoder: ", m_drivetrain.getLeftDistanceInch());
SmartDashboard.putNumber("Drivetrain Left Enoder: ", m_drivetrain.getRightDistanceInch());
SmartDashboard.putString("PhotonVision Has Image: ", camera.toString());
SmartDashboard.putNumber("PhotonVision Pipeline Index: ", (double)camera.getPipelineIndex());
- This autonomous (along with the chooser code above) shows how to select between different
- autonomous modes using the dashboard. The sendable chooser code works with the Java
- SmartDashboard. If you prefer the LabVIEW Dashboard, remove all of the chooser code and
- uncomment the getString line to get the auto name from the text box below the Gyro
You can add additional auto modes by adding additional comparisons to the switch structure
- below with additional strings. If using the SendableChooser make sure to add them to the
- chooser code above as well.
@Override
m_autoSelected = m_chooser.getSelected();
// m_autoSelected = SmartDashboard.getString(“Auto Selector”, kDefaultAuto);
System.out.println("Auto selected: " + m_autoSelected);
m_drivetrain.resetEncoders();
/** This function is called periodically during autonomous. */
@Override
switch (m_autoSelected) {
case kCustomAuto:
// Put custom auto code here
break;
case kDefaultAuto:
default:
// Put default auto code here
break;
/** This function is called once when teleop is enabled. */
@Override
public void teleopInit() {if(runCameraTest){this.cameraTest();}}
/** This function is called periodically during operator control. */
@Override
public void teleopPeriodic() {}
/** This function is called once when the robot is disabled. */
@Override
public void disabledInit() {if(runCameraTest){this.cameraTest();}}
/** This function is called periodically when disabled. */
@Override
public void disabledPeriodic() {}
/** This function is called once when test mode is enabled. */
@Override
public void testInit() {if(runCameraTest){this.cameraTest();}}
/** This function is called periodically during test mode. */
@Override
public void testPeriodic() {
private void cameraTest(){
PhotonPipelineResult photonPipelineResult = camera.getLatestResult();
if (photonPipelineResult.hasTargets()){
var bestTarget = photonPipelineResult.getBestTarget();
SmartDashboard.putNumber("Area: ", bestTarget.getArea());
SmartDashboard.putNumber("Fidicual ID: ", (double)bestTarget.getFiducialId());
SmartDashboard.putNumber("Pitch: ", bestTarget.getPitch());
SmartDashboard.putNumber("Pose: ", bestTarget.getPoseAmbiguity());
SmartDashboard.putNumber("Skew: ", bestTarget.getSkew());
SmartDashboard.putNumber("Yaw: ", bestTarget.getYaw());
SmartDashboard.putString("Corners: ", bestTarget.getCorners().toString());
SmartDashboard.putString("Separator", "---------------------------------------------");
