This is team 4254. This is our rookie year and we need a little help with programming. We have a two person programming team and we both know java from high school courses. We have our robot driving around but we are having difficulties programming the Vex Pro Spike switch. Please help us!
I realize that i gave no info about our problem, but we really have nothing done. We have tried many things but none of them have worked and i think if we just saw an example of code that worked it would help us out a boat load
There are 8 relay ports on the sidecar. They are numbered from 1-8. The number corresponding to the port you plugged the PWM cable from the relay into the sidecar replaces the āPORT YOU PLUGGED THE PWM WIRE INTO ON DSCā in the code.
The rest of the code just initializes the relay using the port. Everything is an object.
