I’ve tried SDP/SI, as far as I could tell they don’t have crown gears stock. This is for a college/for fun project. So the reason I’m looking into crown gears is to minimize the number of custom parts I need. With bevels you have to have two mating bevels and if you need to change the ratio you need to redesign both parts whereas with crown gears I can just adjust the pinion and the mounting distance. Since this is for now a 3D printed part It is a lot easier to change the dimension of one part and adjust the pinion than it is for me to remake both bevels.
I could probably try to find a gear profile program just that is out of my budget for quite a while and this is a project I’m currently interested in and working on.
Involute gears are the most commonly used gear types, However the trick is for crown gears the crown gear has a different profile than a trapezoidal tooth, which is what most of the cad tutorials I have found use.
And the other reason I’m looking into crown gears is I have constraints in my x and y axis but my z axis is more free for adjustments. And since i want to test multiple ratios making one crown gear is easier than a bunch of bevel gear pairs.
