Help with code
We ar having some errors in this area of our code.
  1. double xinput = oi.getDriverJoystick().getX();
  2. double yinput = oi.getDriverJoystick().getY();
  3. if (xinput < 0) {
  4. xinput = -Math.pow(xinput, 2);
  5. }
  6. else {
  7. xinput = Math.pow(xinput, 2);
  8. }
  9. if (yinput < 0) {
  10. yinput = -Math.pow(yinput,2);
  11. }
  12. else {
    184 ) yinput = Math.pow(yinput, 2);
  13. }
187 ) left.set(yinput-xinput);
188) right.set(-yinput-xinput);
Here are the errors that we are getting
C:\2020Coding\Bizcuit\src\main\java\frc\robot\Robot.java:172: error: illegal start of type
if (xinput < 0) {
if (xinput < 0) {
C:\2020Coding\Bizcuit\src\main\java\frc\robot\Robot.java:175: error: illegal start of type
else {
C:\2020Coding\Bizcuit\src\main\java\frc\robot\Robot.java:179: error: illegal start of type
if (yinput < 0) {
if (yinput < 0) {
C:\2020Coding\Bizcuit\src\main\java\frc\robot\Robot.java:182: error: illegal start of type
else {
C:\2020Coding\Bizcuit\src\main\java\frc\robot\Robot.java:186: error: expected
C:\2020Coding\Bizcuit\src\main\java\frc\robot\Robot.java:187: error: expected
C:\2020Coding\Bizcuit\src\main\java\frc\robot\Robot.java:187: error: illegal start of type
C:\2020Coding\Bizcuit\src\main\java\frc\robot\Robot.java:195: error: class, interface, or enum expected
Upload all of your code to Github or another code sharing service so that it is easier for others to help you.
Here is the github link.
Here are the errors again.
Thank you
if (xinput < 0) {
if (xinput < 0) {
else {
if (yinput < 0) {
if (yinput < 0) {
else {
Your immediate problem is the stray } on 157. You need to comment that line out to match its neighbors.
One of the things I do in my own programming is to put a comment on every closing } to match its opening counterpart. I haven’t talked to my programmers lately about this practice. Thanks for jogging my memory!
