http://rapidshare.com/files/183429528/FRC_cRIO_Robot_Project_2902.lvproj
Can someone please help me with the code. I dont have a background with this and i think i have written this correctly.
I even tried to do the simple robot code but to no avail because the motors still dont work.
can someone tell me what i am doing wrong.
Hi Nick,
I’d love to help and I’ll do my best to. However the LabVIEW project file by itself doesn’t contain your robot code, we would also need the “Basic Robot Main.vi” file associated with that project to look at your code.
http://rapidshare.com/files/183440847/Basic_Robot_Main.vi
there have been no changes to this file. because like i said. i dont have a clue about the program
Thanks for your help!
Hmm… Your code looks fine.
It seems that this might be a communications problem? Were there any problems downloading your code? Are you sure all your IP’s are correct?
I don’t think your code is the problem. I would just double check your system, make sure the joystick is in the right port, everything has power, etc.
Let me know how things go!
maybe i dont have everything wired correctly. when i get back in the shop i will take a picture and upload it so that maybe we can get some guidance.
thanks a ton for just looking!
Jim_E
January 14, 2009, 11:17pm
6
We you able to get the hardware working with the test bench?
well we moved too fast and flashed the drivers station and cRIO before testing
