Help with Programming a CIMCODER
I recently got a package of CIMCoders for our Robot’s Drivetrain. The problem is that I’ve never actually programmed encoders before; Especially, CIMCoders. So, I used the example code provided from AndyMark, but I could never get any values from the CIMCoder. I knew the CIMCoder worked because both Channel A and B flashed when I moved the motor. Please help I’m very confused! (Code I used is listed below)
package frc.robot;
import edu.wpi.first.wpilibj.Encoder;
  • The VM is configured to automatically run this class, and to call the functions corresponding to
  • each mode, as described in the TimedRobot documentation. If you change the name of this class or
  • the package after creating this project, you must also update the build.gradle file in the
  • project.
    • This function is run when the robot is first started up and should be used for any
    • initialization code.
Encoder encoder;
private static final double cpr = 64;
private static final double whd = 6;
@Override
public void robotInit() {
encoder = new Encoder(0,1);
encoder.setDistancePerPulse(Math.PIwhd/cpr); //distance per pulse is pi (wheel diameter / counts per revolution)
@Override
public void robotPeriodic() {
double dist = encoder.getDistance();
SmartDashboard.putNumber(“Encoder”, dist);
I recommend printing the value you are sending to setDistancePerPulse. I doubt it’s what you’re expecting.
I’ve also tried that; Doesn’t work either.
UPDATE: I forgot to mention that I’ve plugged my CIMCoder into my TalonSRX. Should I try connecting it to the dio?
If the encoder is on the SRX then you need the configSelectedFeedbackSensor​ method from CTRE to set it up. Like this
TalonSRX motor = new TalonSRX(0);
//Config the CIMcoder
motor.configSelectedFeedbackSensor(FeedbackDevice.QuadEncoder, 0, 30);
//Get the position
motor.getSelectedSensorPosition();
The encoder class from WPIlib won’t work unless the encoder is connected to the dio. The CTRE examples show more of what you can with the encoder.
Thanks. I did not have the CIMCOder plugged into the DIO. Thank you for the help!
Thank you! I was able to wire the power and ground along with the two signal wires to the DIO Port.
