Help with programming Solenoids
I am terrible at programming anything pneumatic related, and solenoids are unfortunately no exception. Netbeans keeps getting an illegal start of expression.
Here is my code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Solenoid;
public class Solenoids {
private Solenoid uno;
private Solenoid dos;
private boolean solenoidBoo = false;
public MySolenoid(1 , 2){
    solenoidBoo = true;
    uno = new Solenoid(8, 1);
    dos = new Solenoid(8, 2);
    System.out.println("We have liftoff" + 1 + " and " + 2);
public void extend() {
    uno.set(true);
    if(solenoidBoo) {
        dos.set(false);
public void retract() {
    uno.set(false);
    if(solenoidBoo) {
        dos.set(true);
public boolean get() {
    return this.uno.get();
 public boolean getDos() {
    boolean otherBoo = dos.get();
    return otherBoo;
Your code would be easier to read if you enclosed it in code] tags. It would also be helpful if you said what line Netbeans was complaining about.
What are you trying to do here? public MySolenoid(1 , 2) isn’t valid syntax for a class declaration, constructor, or method.
In addition, you’ll get a runtime error for uno = new Solenoid(8, 1); because 8 isn’t a valid solenoid module.
