I want my students to write a simple autonomous routine where we back up for a few seconds. (We are using Java with the wpilibj2 library)
In past years, I would have had them use a TimedCommand for this, but I can’t seem to find it in the new version of WPILib. Is there a simple way to run a command for a set amount of time?
If you can’t find it a work around might be to start a timer in the initialize, excute like normal, and then check for a certain time passed in the isFinished method to end.
You could also run a ParallelRaceGroup with a new WaitCommand(time in seconds) and your drive backwards command. Whenever the first command ends which would be the wait command it will end all of them. Not maybe the most elegant way of doing it, but it would work
We just generally use a class level variable such as startTime
In the initialize
startTime=System.currentTimeMillis();
Then in isFinished
return System.currentTimeMillis()-startTime>=targetTime;
where targetTime is the time in milliseconds (usually provided by a parameter in the constructor.
A bit simplistic and other options above might be better but this is easy to understand.
Thank you all for your fast replies. I’ll work with my students and see if withTimeout() works for us, if not we’ll try using System.currentTimeMillis() within the command.
I agree that my solution was not the actual best but, as a mentor, it depends on the knowledge level of students I am working with and where they are at. Assuming they don’t know about timers - is this a case where the simple low level solution is good enough or does this become the “teachable moment” for them to learn about timers (Java native or WPI). Actually what I would really love is for one of them to be curious enough to come here on CD and find a thread like this to see all those better solutions and explore them.
I disagree with this approach to teaching, I think. Why teach students how to do something the wrong way when it is not substantially harder to do it the right way? The method names aren’t any less obvious.
Learning is not linear; there is no knowledge baseline past which it is appropriate to learn about different system timers. The concept is simple, and should be taught as soon as it is relevant.
