We are entering tank drive sample into our last year cRIO and we get this error message:
Access denied: This target is running a version of Labview Real time that is different than the Real-Time Module software on the host computer. You can verify the version and reinstall the Real-Time software using Measurement and Automation Explorer.
We have formatted the cRIO, installed all updates but still get the error.
We had the same problem, try to insert the update USB that has the Labview for this year and run it again. This might fix any old software that might be running. This is how we fix this problem. Let CD know if the problem is still now fixed.
You said that you formatted, but did not say if you re-flashed the cRIO to any specific version. If it is still using the image from last year, this will cause issues.
Yes, you should use that procedure to load image v43 onto your cRIO.
