We are trying to make our robot go to a position zero we set with a button. But the code won’t work.
Have you tuned PID? Can you share the swerve subsystem?
package frc.robot.subsystems;
import frc.robot.SwerveModule;
import frc.robot.Constants;
import edu.wpi.first.math.kinematics.ChassisSpeeds;
import edu.wpi.first.math.kinematics.SwerveDriveKinematics;
import edu.wpi.first.math.kinematics.SwerveDriveOdometry;
import edu.wpi.first.math.kinematics.SwerveModulePosition;
import java.util.List;
import com.ctre.phoenix.sensors.Pigeon2;
import com.pathplanner.lib.PathConstraints;
import com.pathplanner.lib.PathPlanner;
import com.pathplanner.lib.PathPlannerTrajectory;
import com.pathplanner.lib.PathPoint;
import com.pathplanner.lib.commands.PPSwerveControllerCommand;
import edu.wpi.first.math.controller.PIDController;
import edu.wpi.first.math.estimator.SwerveDrivePoseEstimator;
import edu.wpi.first.math.geometry.Pose2d;
import edu.wpi.first.math.geometry.Rotation2d;
import edu.wpi.first.math.geometry.Translation2d;
import edu.wpi.first.math.kinematics.SwerveModuleState;
import edu.wpi.first.networktables.GenericEntry;
import edu.wpi.first.networktables.NetworkTable;
import edu.wpi.first.networktables.NetworkTableEntry;
import edu.wpi.first.networktables.NetworkTableInstance;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.shuffleboard.Shuffleboard;
import edu.wpi.first.wpilibj.shuffleboard.ShuffleboardTab;
import edu.wpi.first.wpilibj2.command.Command;
import edu.wpi.first.wpilibj2.command.InstantCommand;
import edu.wpi.first.wpilibj2.command.SequentialCommandGroup;
import edu.wpi.first.wpilibj2.command.SubsystemBase;
public class Swerve extends SubsystemBase {
public SwerveDriveOdometry swerveOdometry;
public SwerveDrivePoseEstimator SwervePoseEstimator;
public SwerveModule[] mSwerveMods;
public Pigeon2 gyro;
public PIDController anglePID ;
public PIDController XPID ;
public PIDController YPID ;
public PIDController balancePID;
private int AutoPilotTarget;
private ShuffleboardTab tab = Shuffleboard.getTab("Dashboard");
private GenericEntry AutoPilotSection = tab.add("AP Selection",0).withPosition(1, 0).getEntry();
public Swerve() {
anglePID = new PIDController(0.005, 0.0001, 0);
anglePID.enableContinuousInput(0, 360);
XPID=new PIDController(0.5,0,0);
YPID=new PIDController(0.5,0,0);
balancePID = new PIDController(0.007, 0.00015, 0.00035);
AutoPilotTarget=0;
gyro = new Pigeon2(Constants.Swerve.pigeonID);
gyro.configFactoryDefault();
zeroGyro();
mSwerveMods = new SwerveModule[] {
new SwerveModule(0, Constants.Swerve.Mod0.constants),
new SwerveModule(1, Constants.Swerve.Mod1.constants),
new SwerveModule(2, Constants.Swerve.Mod2.constants),
new SwerveModule(3, Constants.Swerve.Mod3.constants)
/* By pausing init for a second before setting module offsets, we avoid a bug with inverting motors.
* See https://github.com/Team364/BaseFalconSwerve/issues/8 for more info.
Timer.delay(1.0);
resetModulesToAbsolute();
swerveOdometry = new SwerveDriveOdometry(Constants.Swerve.swerveKinematics, getYaw(), getModulePositions());
SwervePoseEstimator = new SwerveDrivePoseEstimator(Constants.Swerve.swerveKinematics, getYaw(), getModulePositions(), getPose());
/*Default drive state for teleop */
public void drive(Translation2d translation, double rotation, boolean fieldRelative, boolean isOpenLoop) {
SwerveModuleState[] swerveModuleStates =
Constants.Swerve.swerveKinematics.toSwerveModuleStates(
fieldRelative ? ChassisSpeeds.fromFieldRelativeSpeeds(
translation.getX(),
translation.getY(),
rotation,
getYaw()
: new ChassisSpeeds(
translation.getX(),
translation.getY(),
rotation)
SwerveDriveKinematics.desaturateWheelSpeeds(swerveModuleStates, Constants.Swerve.maxSpeed);
for(SwerveModule mod : mSwerveMods){
mod.setDesiredState(swerveModuleStates[mod.moduleNumber], isOpenLoop);
/*Drive state with rotation locked to cardinal directions */
public void lockedrive(Translation2d translation, boolean fieldRelative, boolean isOpenLoop, double setPoint) {
translation.getX(),
translation.getY(),
anglePID.calculate(gyro.getYaw(), setPoint),
getYaw()
translation.getX(),
translation.getY(),
anglePID.calculate(gyro.getYaw(), setPoint))
public void balanceDrive(Translation2d translation, boolean fieldRelative, boolean isOpenLoop) {
(balancePID.calculate(gyro.getPitch(), 0)*0.5),
translation.getY(),
anglePID.calculate(gyro.getYaw(), 0),
getYaw()
translation.getY(),
anglePID.calculate(gyro.getYaw(), 0))
/*Updates current autopilot target location selection */
public void AutoPilotDestinationSelector(int index){
AutoPilotTarget = index;
/*Establishes an origin point in the field */
public void ReturnToOrigin(){
/* Used by SwerveControllerCommand in Auto */
public void setModuleStates(SwerveModuleState[] desiredStates) {
SwerveDriveKinematics.desaturateWheelSpeeds(desiredStates, Constants.Swerve.maxSpeed);
mod.setDesiredState(desiredStates[mod.moduleNumber], false);
public void setModuleStatesAuto(SwerveModuleState[] desiredStates) {
SwerveDriveKinematics.desaturateWheelSpeeds(desiredStates, Constants.AutoConstants.kMaxSpeedMetersPerSecond);
public Pose2d getPose() {
return swerveOdometry.getPoseMeters();
public Pose2d getEstimatedPose() {
return SwervePoseEstimator.getEstimatedPosition();
public void resetOdometry(Pose2d pose) {
swerveOdometry.resetPosition(getYaw(), getModulePositions(), pose);
public void resetEstimation(Pose2d pose) {
SwervePoseEstimator.resetPosition(getYaw(), getModulePositions(), pose);
public SwerveModuleState[] getModuleStates(){
SwerveModuleState[] states = new SwerveModuleState[4];
states[mod.moduleNumber] = mod.getState();
return states;
public SwerveModulePosition[] getModulePositions(){
SwerveModulePosition[] positions = new SwerveModulePosition[4];
positions[mod.moduleNumber] = mod.getPosition();
return positions;
public void zeroGyro(){
gyro.setYaw(0);
public void zeropos(){
swerveOdometry.resetPosition(getYaw(), getModulePositions(), getEstimatedPose());
public Rotation2d getYaw() {
return (Constants.Swerve.invertGyro) ? Rotation2d.fromDegrees(360 - gyro.getYaw()) : Rotation2d.fromDegrees(gyro.getYaw());
public void resetModulesToAbsolute(){
mod.resetToAbsolute();
public double getArea(){
NetworkTable table = NetworkTableInstance.getDefault().getTable("limelight");
NetworkTableEntry ta = table.getEntry("ta");
double a = ta.getDouble(0.0);
return a;
public double[] getLimeInfo(){
* 1-x
* 0-y
* 2-z
* 3-Roll
* 4-Pitch
* 5-Yaw
if(NetworkTableInstance.getDefault().getTable("limelight").getEntry("tid").getInteger(0)!=-1.0){
return NetworkTableInstance.getDefault().getTable("limelight").getEntry("botpose").getDoubleArray(new double[6]);
else{
double[] blank={0,0,0,0,0,0};
return blank;
public double getLimeDelay(){
double tl = NetworkTableInstance.getDefault().getTable("limelight").getEntry("tl").getDouble(0);
double cl= NetworkTableInstance.getDefault().getTable("limelight").getEntry("cl").getDouble(0);
return (tl+cl);
public void VisionResetEstimation() {
double[] Limeinfo = getLimeInfo();
Pose2d pose=new Pose2d(new Translation2d(Limeinfo[0]+8.3, Limeinfo[1]+4.1), new Rotation2d(Limeinfo[5]));
if(Limeinfo[0]!=0 && Limeinfo[1]!=0){
resetOdometry(pose);
public PathPlannerTrajectory generate_AP_Path(){
PathPlannerTrajectory traj = PathPlanner.generatePath(
new PathConstraints(4, 3),
new PathPoint(new Translation2d(Constants.AutoPilotLocations[AutoPilotTarget].getX()/2, Constants.AutoPilotLocations[AutoPilotTarget].getY()/2), Rotation2d.fromDegrees(45), Constants.AutoPilotLocations[AutoPilotTarget].getRotation()),
new PathPoint(new Translation2d(Constants.AutoPilotLocations[AutoPilotTarget].getX(), Constants.AutoPilotLocations[AutoPilotTarget].getY()), Rotation2d.fromDegrees(45), Constants.AutoPilotLocations[AutoPilotTarget].getRotation()));
return traj;
public Command followTrajectoryCommand(PathPlannerTrajectory traj, boolean isFirstPath) {
return new SequentialCommandGroup(
new InstantCommand(() -> {
// Reset odometry for the first path you run during auto
if(isFirstPath){
this.resetOdometry(traj.getInitialHolonomicPose());
new PPSwerveControllerCommand(
traj,
this::getPose, // Pose supplier
Constants.Swerve.swerveKinematics, // SwerveDriveKinematics
new PIDController(0.5, 0, 0), // X controller. Tune these values for your robot. Leaving them 0 will only use feedforwards.
new PIDController(0.5, 0, 0), // Y controller (usually the same values as X controller)
new PIDController(0.5, 0, 0), // Rotation controller. Tune these values for your robot. Leaving them 0 will only use feedforwards.
this::setModuleStatesAuto, // Module states consumer
false, // Should the path be automatically mirrored depending on alliance color. Optional, defaults to true
this // Requires this drive subsystem
public PathPlannerTrajectory generate_Origin_Path(){
PathPlannerTrajectory origin = PathPlanner.generatePath(
new PathConstraints(0.5, 0.3),
new PathPoint(new Translation2d(swerveOdometry.getPoseMeters().getX(), swerveOdometry.getPoseMeters().getY()), Rotation2d.fromDegrees(45), swerveOdometry.getPoseMeters().getRotation()),
new PathPoint(new Translation2d(0, 0), Rotation2d.fromDegrees(45), 0));
return origin;
public Command followOrigin(PathPlannerTrajectory origin) {
origin,
@Override
public void periodic(){
swerveOdometry.update(getYaw(), getModulePositions());
//SwervePoseEstimator.addVisionMeasurement(new Pose2d(new Translation2d(Limeinfo[1]+8.3, Limeinfo[0]+4.1), new Rotation2d(Limeinfo[5])), Timer.getFPGATimestamp()-getLimeDelay());
//SwervePoseEstimator.update(getYaw(), getModulePositions());
SmartDashboard.putNumber("LimePose X", Limeinfo[0]+8.3);
SmartDashboard.putNumber("LimePose Y", Limeinfo[1]+4.1);
SmartDashboard.putNumber("EncoderPose X", getPose().getX());
SmartDashboard.putNumber("EncoderPose Y", getPose().getY());
//Pose2d estPose= SwervePoseEstimator.getEstimatedPosition();
//SmartDashboard.putNumber("Estx",estPose.getX());
//SmartDashboard.putNumber("Esty",estPose.getY());
SmartDashboard.putNumber("Mod " + mod.moduleNumber + " Cancoder", mod.getCanCoder().getDegrees());
SmartDashboard.putNumber("Mod " + mod.moduleNumber + " Integrated", mod.getPosition().angle.getDegrees());
SmartDashboard.putNumber("Mod " + mod.moduleNumber + " Velocity", mod.getState().speedMetersPerSecond);
AutoPilotSection.setDouble(AutoPilotTarget);
I tried adding .execute, that way it gives me the startcompetition error
package frc.robot.commands;
import frc.robot.subsystems.Swerve;
import edu.wpi.first.wpilibj2.command.CommandBase;
public class AutoDriveToOrigin extends CommandBase {
/** Creates a new AutoDriveToOrigin. */
private Swerve s_Swerve;
public AutoDriveToOrigin(Swerve s_sSwerve) {
// Use addRequirements() here to declare subsystem dependencies.
this.s_Swerve = s_sSwerve;
addRequirements(s_sSwerve);
// Called when the command is initially scheduled.
@Override
public void initialize() {
// Called every time the scheduler runs while the command is scheduled.
@Override
public void execute() {
s_Swerve.followOrigin(s_Swerve.generate_Origin_Path()).execute();
// Called once the command ends or is interrupted.
@Override
public void end(boolean interrupted) {}
// Returns true when the command should end.
@Override
public boolean isFinished() {
return false;
Cool the issue is that you don’t need a now command because public Command followOrigin(PathPlannerTrajectory origin)
returns a Command
you can just directly execute it with Trigger.whileTrue(s_Swerve.followOrigin(s_Swerve.generate_Origin_Path()))
You should also never run a command via execute. You want to scheduled it.
If you have any more questions a GitHub link would help a lot!
Hi, thank you, we were using .execute because of a example we saw in another code, but withouth it the robot simly does nothing, i’ll send you the subsystem for generating paths that we are trying to use.
p.s. The solutin you sent isn’t working, it says it cannot make a reference to the non static method whileTrue
return origin;
origin,
You need to use the instance of the subsystem class s_Swerve
. It is what you pass into AutoDriveToOrigin(Swerve s_sSwerve)
