Hey guys, I have a problem with my code based on commands, when the code is executed together with the FMS, the roborio is crashing, when I run the code connected directly to the robot, no error appears, I believe that in some disable method, they could give a look?
One thing I notice is that you’re setting alliance colour using a SendableChooser when you could be calling DriverStation.getInstance().getAlliance(). Edit: This is unlikely to be the cause of your problem.
Can you reproduce the problem using “test” mode? Does the problem happen with all autos or just one?
Have you tried running “Practice” mode in the DS? This runs autonomous mode, followed by teleop mode, just like a real match, and can help discover code issues related to transitions between auto and teleop.
