I’m attempting to set up a dev system and integrate Grip vision (Java) on a raspberry Pi 3.
https://wpilib.screenstepslive.com/s/currentCS/m/vision/l/687863-off-board-vision-processing-in-java
From the screensteps documentation above I found the following link and installed and compiled built the example using gradlew. this created a deployable jar that can be copied to the raspberry PI and ran on it. Note that all of the build was performed on a Windows 10 laptop.
I created a pipeline using Grip and saved it as a java file… moved it to the build directory and tried to build in running gradlew and received the following error:
package edu.wpi.first.wpilibj.vision does not exist
I’ve searched my pc and did not find wpilibj.jar anywhere… I do have wpilib.
I also have eclipse installed and cannot compile the pipeline because wpilibj is not found.
I’ve searched the web extensively and found the site with the wpilib source files but there are no jar files there. I downloaded and tried to build them and the build crashed. I did not initially have C++ compiler installed so I installed Visual Studio free version and the build still crashed.
My goal is to build an executable jar like the example that calls the pipeline from Grip. Any suggestions? Where do I find wpilibj.jar … I really don’t want to have a c compiler on my pc as I’m not using C.
Any suggestions for how to call the Grip pipeline from the example from screensteps?
