First time programmer needing help. Does anyone know why this program doesn’t work? I have been told to switch the open and close to 1s. But other than that I have no clue what’s wrong. Thanks for any help!
The red dots on the blocks warn of a possible data type mismatch. Right click on the Solenoid Set VI’s value terminal and click on Create Constant. This will give you the correct choices to choose from to input into your Select Comparison blocks.
“Stop” “Open” “Close” are not valid Solenoid settings.
Follow Calvin’s suggestion to get the correct choices.
