Help!
We are less than a week out from regionals! Our Apple programmer who came to “help” our team decided that we needed to update our LabView software (we did not) and proceeded to update it without my permission. He spent six hours trying to figure out how to do it with no luck. When I looked at our computer, the old version is gone along with our program! Whatever version of LabView he half-installed does not work. When I try to download the 2020 version from NI it will not. Any ideas?
Be warned, take my advice cautiously(I do cad not code),
With that said, maybe you could try to finish installing the newest version yourself.
Also rip
Will not what? Download or install?
You will have to uninstall anything NI related before you install the 2022 Labview for FRC.
Are you using this guide to uninstall and install LabView for FRC?
https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-2/labview-setup.html
Given they changed your software stack, I wouldn’t trust what you have on that PC to be tested to work with the 2020 FRC Season. I’d follow the guidance from AfterTen here and uninstall everything. After that, install LabVIEW Software for FRC 2022 followed by FRC Game Tools 2022.
Uninstalling LabVIEW shouldn’t have removed your robot code. It just removed links from LabVIEW to where that code exists. I’m at the wrong PC so I can’t pull up that folder (and don’t have it memorized). If you look to create a new project, it’ll give you the default folder in the wizard. You can go there and should be able to find your old robot code to start from.
What team are you on? Where are you located? Having someone local help you is the first best option.
