Here is an WPILIB AprilTags detection code for C++
If you need an example of doing AprilTags detection on the roboRIO in C++, here it is. I’m working on getting it into the example for wpilib, but there are some details about packaging and wording that will keep that from getting put in real soon. I know people are trying to prototype stuff, and getting an Raspberry Pi for a coprocessor is about impossible right now.
No laughing. C++ is not something I’ve done before.
// Copyright (c) FIRST and other WPILib contributors.
// Open Source Software; you can modify and/or share it under the terms of
// the WPILib BSD license file in the root directory of this project.
#include <cstdio>
#include <span>
#include <sstream>
#include <string>
#include <thread>
#include <cameraserver/CameraServer.h>
#include <frc/TimedRobot.h>
#include <frc/apriltag/AprilTagDetection.h>
#include <frc/apriltag/AprilTagDetector.h>
#include <frc/apriltag/AprilTagPoseEstimator.h>
#include <frc/geometry/Transform3d.h>
#include <frc/smartdashboard/SmartDashboard.h>
#include <opencv2/core/core.hpp>
#include <opencv2/core/types.hpp>
#include <opencv2/imgproc/imgproc.hpp>
#include <units/angle.h>
#include <units/length.h>
 * This is a demo program showing the detection of AprilTags.
 * The image is acquired from the USB camera, then any detected AprilTags
 * are marked up on the image and sent to the dashboard.
class Robot : public frc::TimedRobot {
#if defined(__linux__) || defined(_WIN32)
 private:
  static void VisionThread() {
    frc::AprilTagDetector detector;
    // look for tag16h5, don't correct any error bits
    detector.AddFamily("tag16h5", 0);
    // Set up Pose Estimator - parameters are for a Microsoft Lifecam HD-3000
    // (https://www.chiefdelphi.com/t/wpilib-apriltagdetector-sample-code/421411/21)
    frc::AprilTagPoseEstimator::Config poseEstConfig = {
        .tagSize = units::length::inch_t(6.0),
        .fx = 699.3778103158814,
        .fy = 677.7161226393544,
        .cx = 345.6059345433618,
        .cy = 207.12741326228522};
    frc::AprilTagPoseEstimator estimator =
        frc::AprilTagPoseEstimator(poseEstConfig);
    // Get the USB camera from CameraServer
    cs::UsbCamera camera = frc::CameraServer::StartAutomaticCapture();
    // Set the resolution
    camera.SetResolution(640, 480);
    // Get a CvSink. This will capture Mats from the Camera
    cs::CvSink cvSink = frc::CameraServer::GetVideo();
    // Setup a CvSource. This will send images back to the Dashboard
    cs::CvSource outputStream =
        frc::CameraServer::PutVideo("Detected", 640, 480);
    // Mats are very memory expensive. Lets reuse this Mat.
    cv::Mat mat;
    cv::Mat grayMat;
    // Instantiate once
    std::vector<int> tags;
    cv::Scalar outlineColor = cv::Scalar(0, 255, 0);
    cv::Scalar crossColor = cv::Scalar(0, 0, 255);
    while (true) {
      // Tell the CvSink to grab a frame from the camera and
      // put it
      // in the source mat.  If there is an error notify the
      // output.
      if (cvSink.GrabFrame(mat) == 0) {
        // Send the output the error.
        outputStream.NotifyError(cvSink.GetError());
        // skip the rest of the current iteration
        continue;
      cv::cvtColor(mat, grayMat, cv::COLOR_BGR2GRAY);
      cv::Size g_size = grayMat.size();
      frc::AprilTagDetector::Results detections =
          detector.Detect(g_size.width, g_size.height, grayMat.data);
      // have not seen any tags yet
      tags.clear();
      for (const frc::AprilTagDetection* detection : detections) {
        // remember we saw this tag
        tags.push_back(detection->GetId());
        // draw lines around the tag
        for (int i = 0; i <= 3; i++) {
          int j = (i + 1) % 4;
          const frc::AprilTagDetection::Point pti = detection->GetCorner(i);
          const frc::AprilTagDetection::Point ptj = detection->GetCorner(j);
          line(mat, cv::Point(pti.x, pti.y), cv::Point(ptj.x, ptj.y),
               outlineColor, 2);
        // mark the center of the tag
        const frc::AprilTagDetection::Point c = detection->GetCenter();
        int ll = 10;
        line(mat, cv::Point(c.x - ll, c.y), cv::Point(c.x + ll, c.y),
             crossColor, 2);
        line(mat, cv::Point(c.x, c.y - ll), cv::Point(c.x, c.y + ll),
             crossColor, 2);
        // identify the tag
        putText(mat, std::to_string(detection->GetId()),
                cv::Point(c.x + ll, c.y), cv::FONT_HERSHEY_SIMPLEX, 1,
                crossColor, 3);
        // determine pose
        frc::Transform3d pose = estimator.Estimate(*detection);
        // put pose into dashbaord
        std::stringstream dashboardString;
        dashboardString << "Translation: " << units::length::to_string(pose.X())
                        << ", " << units::length::to_string(pose.Y()) << ", "
                        << units::length::to_string(pose.Z());
        frc::Rotation3d rotation = pose.Rotation();
        dashboardString << "; Rotation: "
                        << units::angle::to_string(rotation.X()) << ", "
                        << units::angle::to_string(rotation.Y()) << ", "
                        << units::angle::to_string(rotation.Z());
        frc::SmartDashboard::PutString(
            "pose_" + std::to_string(detection->GetId()),
            dashboardString.str());
      // put list of tags onto dashboard
      std::stringstream tags_s;
      if (tags.size() > 0) {
        if (tags.size() > 1) {
          std::copy(tags.begin(), tags.end() - 1,
                    std::ostream_iterator<int>(tags_s, ","));
        tags_s << tags.back();
      frc::SmartDashboard::PutString("tags", tags_s.str());
      // Give the output stream a new image to display
      outputStream.PutFrame(mat);
#endif
  void RobotInit() override {
    // We need to run our vision program in a separate thread. If not, our robot
    // program will not run.
    std::thread visionThread(VisionThread);
    visionThread.detach();
#else
    std::fputs("Vision only available on Linux or Windows.\n", stderr);
    std::fflush(stderr);
#endif
#ifndef RUNNING_FRC_TESTS
int main() {
  return frc::StartRobot<Robot>();
#endif
