HERO Board C# Connecting a Xbox Controller
To start this off I am in no way a programmer. But I am doing this as a part of my Senior Capstone Project. Any help is appreciated.
So Tl:dr I have a HERO Board with a Falcon and a Talon SRX (connected to 775 Pro) connected Via CAN. The other night I got a random Logitech Attack 3 Joystick to work and move the motors with this code:
using Microsoft.SPOT;
using Microsoft.SPOT.Hardware;
using System;
using System.Threading;
using CTRE.Phoenix;
using CTRE.Phoenix.Controller;
using CTRE.Phoenix.MotorControl;
using CTRE.Phoenix.MotorControl.CAN;
namespace HERO_Simple_Application1
public class Program
public static void Main()
/Game Pad/
CTRE.Phoenix.Controller.GameController myGamepad = new
CTRE.Phoenix.Controller.GameController(new CTRE.Phoenix.UsbHostDevice(0));
/* create a talon, the Talon Device ID in HERO LifeBoat is zero /
CTRE.Phoenix.MotorControl.CAN.TalonSRX balance = new
CTRE.Phoenix.MotorControl.CAN.TalonSRX(1);
CTRE.Phoenix.MotorControl.CAN.TalonFX drive = new
CTRE.Phoenix.MotorControl.CAN.TalonFX(2);
simple counter to print and watch using the debugger /
int counter = 0;
loop forever */
while (true)
            if (myGamepad.GetConnectionStatus() == CTRE.Phoenix.UsbDeviceConnection.Connected)
                Debug.Print("axis:" + myGamepad.GetAxis(1));
                /* pass axis value to talon */
                balance.Set(CTRE.Phoenix.MotorControl.ControlMode.PercentOutput, myGamepad.GetAxis(0));
                drive.Set(CTRE.Phoenix.MotorControl.ControlMode.PercentOutput, myGamepad.GetAxis(1));
                CTRE.Phoenix.Watchdog.Feed();
            } else
                Debug.Print("Not Connected");
            /* print the three analog inputs as three columns */
            Debug.Print("Counter Value: " + counter);
            /* increment counter */
            ++counter; /* try to land a breakpoint here and hover over 'counter' to see it's current value.  Or add it to the Watch Tab */
            /* wait a bit */
            System.Threading.Thread.Sleep(10);
The attack 3 I have tho is very iffy, and doesnt always stay or get connected. So I want to use my wireless Xbox One controller. For the time being I have the Xbox tethered over USB (as I need to find the wireless dongle)
The HERO board User Guide says that I can just replace the class “GameController” can be replaced with “Xbox360Gamepad”
When I do that on these 2 lines:
I get the error:
Xbox360Gamepad.Xbox360Gamepad(IGameControllerValuesProvider, uint idx)
There is no argument given that corresponds to the required formal parameter ‘idx’ of ‘Xbox360Gamepad.Xbox360Gamepad(IGameControllerValuesProvider, unit)’
I did look at some C# Examples from the HERO Github.
This code will deploy to the device but doesnt recognize the controller as being connected.
  • Test project for using the Xbox360 Controller (and F710 gamepad in XInput Mode).
  • This will be supported in the next release of the CTR Toolsuite (Coming soon).
  • This test project will likely require HERO 0.14.X.X (expect a few tweaks before then).
  • Xinput mode on F710 gives us…
    • analog shoulder triggers (not just digitial)
    • vibration
    • LED control (if using XBOX 360 controller)
    • More resolute axis data (16bit)
using System;
using System.Text;
using CTRE.Phoenix;
namespace HERO_XInput_Gampad_Example
/* the goal is to plug in a Xinput Logitech Gamepad or Xbox360 style controller */
GameController _gamepad = new GameController(UsbHostDevice.GetInstance(0));
    //TalonSRX _tal = new TalonSRX(44);
    /* Create the DriverModule to control some LEDs or solenoids */
    CTRE.Gadgeteer.Module.DriverModule _driver = new CTRE.Gadgeteer.Module.DriverModule(CTRE.HERO.IO.Port5);
    bool[] _buttons = new bool[20];
    float[] _sticks = new float[6];
    /* dont let rumbling go for too long, otherwise it will eat up battery */
    int _rumblingTimeMs = 0;
    int _rumblinSt = 0;
    public void RunForever()
        /* enable XInput, if gamepad is in DInput it will disable robot.  This way you can
         * use X mode for drive, and D mode for disable (instead of vice versa as the
         * stock HERO implementation traditionally does). */
        UsbHostDevice.GetInstance(0).SetSelectableXInputFilter(UsbHostDevice.SelectableXInputFilter.XInputDevices);
        /* Factory Default all hardware to prevent unexpected behaviour */
        // _tal.ConfigFactoryDefault();
        while (true)
            if (_gamepad.GetConnectionStatus() == UsbDeviceConnection.Connected)
                Watchdog.Feed();
            /* get buttons */
            bool[] btns = new bool[_buttons.Length];
            for (uint i = 1; i < 20; ++i)
                btns[i] = _gamepad.GetButton(i);
            /* get sticks */
            for (uint i = 0; i < _sticks.Length; ++i)
                _sticks[i] = _gamepad.GetAxis(i);
            /* yield for a bit, and track timeouts */
            if (_rumblingTimeMs < 5000)
                _rumblingTimeMs += 10;
            /* update the Talon using the shoulder analog triggers */
            //_tal.Set(ControlMode.PercentOutput, (_sticks[5] - _sticks[4]) * 0.60f);
            /* fire some solenoids based on buttons */
            _driver.Set(1, _buttons[1]);
            _driver.Set(2, _buttons[2]);
            _driver.Set(3, _buttons[3]);
            _driver.Set(4, _buttons[4]);
            /* rumble state machine */
            switch (_rumblinSt)
                /* rumbling is disabled, require some off time to save battery */
                case 0:
                    _gamepad.SetLeftRumble(0);
                    _gamepad.SetRightRumble(0);
                    if (_rumblingTimeMs < 100)
                        /* waiting for off-time */
                    else if ((btns[1] && !_buttons[1])) /* button off => on */
                        /* off time long enough, user pressed btn */
                        _rumblinSt = 1;
                        _gamepad.SetLeftRumble(0xFF);
                    else if ((btns[2] && !_buttons[2])) /* button off => on */
                        _rumblinSt = 1;
                        _gamepad.SetRightRumble(0xFF);
                    break;
                /* already vibrating, track the time */
                case 1:
                    if (_rumblingTimeMs > 500)
                        /* vibrating too long, turn off now */
                        _rumblinSt = 0;
                    else if ((btns[3] && !_buttons[3]))  /* button off => on */
                        /* immedietely turn off */
                        _rumblinSt = 0;
                    break;
            /* this will likley be replaced with a strongly typed interface,
             * control the LEDs on the center XBOX emblem. */
            if (btns[5] && !_buttons[5]) { _gamepad.SetLEDCode(6); }
            if (btns[6] && !_buttons[6]) { _gamepad.SetLEDCode(7); }
            if (btns[7] && !_buttons[7]) { _gamepad.SetLEDCode(8); }
            if (btns[8] && !_buttons[8]) { _gamepad.SetLEDCode(9); }
            /* build line to print */
            StringBuilder sb = new StringBuilder();
            foreach (float stick in _sticks)
                sb.Append(Format(stick));
                sb.Append(",");
            if (_gamepad.GetConnectionStatus() == CTRE.Phoenix.UsbDeviceConnection.Connected)
                Debug.Print("axis:" + _gamepad.GetAxis(1));
            else
            sb.Append("-");
            for (uint i = 1; i < _buttons.Length; ++i)
                if (_buttons[i])
                    sb.Append("b" + i + ",");
            /* print useful info */
            sb.AppendLine();
            Debug.Print(sb.ToString());
            /* save button states for button-change states */
            _buttons = btns;
            balance.Set(CTRE.Phoenix.MotorControl.ControlMode.PercentOutput, _gamepad.GetAxis(0));
            drive.Set(CTRE.Phoenix.MotorControl.ControlMode.PercentOutput, _gamepad.GetAxis(1));
        else
     * @param x arbitrary float
     * @return string version of x truncated to "X.XX"
    String Format(float x)
        x *= 100;
        x = (int)x;
        x *= 0.01f;
        return "" + x;
        new Program().RunForever();
(There is a lot of fluff in this code that I don’t/cant use, but I didn’t remove any for fear it actually does something important.)
Thanks again to those who made it through all of that. Any and all help is appreciated
