hex file garbage?
There’s two lines at the end of the hex files that I can’t figure out. They’re the 3rd and 2nd to last (the two before the last line).
:020000040030CA
:0E000000FFFEFEFCFFFEFBFFFFFFFFFFFFFF0A
I can’t figure out exactly what they do. From what I understand, the first one
:020000040030CA
says to prepend 0x0030 to the address of any data records that come after it. That would mean however, the the next line
writes data to 0x00300000, which as far as I can tell, doesn’t exist. The last address in the flash memory is 0x7FFF.
Any ideas?
No ideas, but I’m inpressed you understood all but two lines… :ahh:
Wow… nice. I’m in awe. :eek:
The code memory space ends at 0x7FFF but the highest flash address on the 18F8520 is 0x3FFFFF. The memory addresses from 0x300000 - 0x30000D are used for the device’s configuration settings such as clock source, code protect, etc. Addresses 0x3FFFFE and 0x3FFFFF are for the device ID bits.
