Hello I was recently talking to someone about hex shafts and i was wondering where to get them. I was looking around McMaster and this is what I found. Is this ok to use or are there other hex shafts out there that I should look at that are designed for this.
but a few questions about hex shafts,
Are there any tricks that go into using hex shafts VS key shafts?
Have you had any problems with hex shafts?
What are the benefits of Hex shafts?
I assume you’ve already looked at what AndyMark has to offer.
For what specific purpose are you using the hex shafts? If we know more about your problem, we can offer better solutions.
yes I have I was wanting to make a drive that used hex shafts (a 6/8wd) i was going to use this to drive the main wheel but i was looking to drive the corner wheels as well with hex, plus if i wanted to make an arm drive by hex shafts, or a fly wheel.
The primary benefit of hex shafting is that there is no key needed. Which means no key to fall out at an inopportune time and no keyway to cut which saves machining time. It is also an alternative if you don’t have the equipment to cut a keyway, like a mill. Yes, you could get shafting with a keyway already in it, but then you need to stop the key from moving too far.
The only difficulties that I have encountered with hex shafting are difficulty with finding mating parts (bearings & hubs), and shaft tolerances. AndyMark has largely solved that first problem for 1/2" & 3/8" shafts. Shaft tolerances can still be a gotcha if you are not paying attention. For example, the shafting you link to is 1/2" +/-.005" which means it’s actual size may be anywhere from .495-.505". An AM hex hub (AM-0096) has a hex bore of .501-.505" per the web site. If your hub comes in on the low side and the shaft on the high side it won’t fit. (.505" shaft going into a .501" bore) Something with have to give to make that fit. Alternatively, McMaster 6607K43 is also a 1/2" hex, but with a +0 -.008 tolerance for actual size limits of .492-.500" It should always fit in the AM hex hub.
I find it easier to locate mating hex shaft in steel, but the decision between steel and aluminum should really be based upon your load requirements.
As always, Mark has wonderful advice. We have noticed that our aluminum hex shafts are often tight fits into our hex hubs. This is exactly due to the reasons Mark lists above. We have found that the best and easiest way to take 1 or 2 thousandths off of a side is to carefully and evenly use a belt sander on each of the 6 sides of the shaft.
Also, another reason why it is beneficial to use a hex shaft is that the torque load is now distributed across 6 different points of contact (the six corners of the hex shaft) as opposed to the concentrated point of the keyway.
We use 2024 and 2021 aluminum for these lightweight applications.
I have to second that. We used hex shafts in our 6WD in 2008 (which was the first year we made the switch from keyed shafts after what I believe was a sheared keyway in 2007, same drivetrain), initially made of steel. We brought aluminum replacements to our first competition to try and save a little on weight. I don’t know what kind of aluminum we used - Mark, you might know - but we ended up with an axle that had to be sheared off and pounded out of the wheel (if I remember correctly, it got bent during a match).
Every bot is different, but make sure that you know exactly what kind of performance you need from your shafts, including any mishaps that may happen in a match setting. The drivetrain is the one assembly that you can’t afford to have knocked out.
We have typically run 6061 hex on our drive train with fairly little issue. Again as people have mentioned before, understanding the loading is of the up most importance. Our drive shafts are doubly supported (we do not cantilever) which puts the loads well within 6061’s range. So bottom line “do the math”
Only issues we have had was a some galling issues between the alum. shaft and the alum. wheel. Usually only occurs when the hex was too tight of a fit to begin with.
I’ve bought 7075 1/2" hex from Fry Steel for REALLY cheap. We’re talking about $18 for a 12 foot piece. They may be able to ship it, call them. I think I recall it being about a thousandth or so oversize. Nothing a little bit of sandpaper and a few minutes couldn’t fix.
We were hesitant at first to try hex but have used AM hex products for two seasons with great results. Even flying over the humps in 2010 we never had a failure.
The best place on the west coast for 7075 of any profile is Fry Steel, in our experience.
Tolerance on the hex is a constant battle for us as well. We either need to broach the mating piece multiple times or use a 3M deburring wheel to knock a little off the flats of the hex. We’ve tried using an oversized hex broach but it’s unpredictable whether you end up with a nice fit or a sloppy fit and it does you no good when your mating piece came stock with a hex in it.
Thanks for all the responses guys. But on buying the hex no where in Austin stocks hex in 7075 it’s just 6061. But what were some problem y’all had with the 6061 hex? (sorry for the limited respons I am away from my comp. right now)
During the middle of the 2010 season we switched our transmission output shafts from keyed to hex due to numerous keys sheared the previous three years. We will never go back to keys, and you will probably see us use hex in other applications also.
Actually, now that I think about it, we used a hex shaft on our custom worm gearbox this past year for the tower. No problems at all from the hex, but some other things in the gearbox were problems.
