Hey
Hey I need a bit of help im new to robotics this year and I got Windriver and I really don’t know where to start. I have the Eclipse environment and windriver but I don’t know what library’s I should get.
If you follow this link there are some good tutorials to use.
http://www.cprogramming.com/tutorial.html#c++tutorial
You can just press close in the bottom right corner when the window pops up.
Also, use the C++ tutorials.
Eclipse also has some good tutorials built in if you go to the help menu.
Would you say that cplusplus.com is better or cprogramming.com is better.
I haven’t used cplusplus, so it’s up to you. I used cprogramming and I think it works just fine.
