And heres my class code
package frc.robot;
import edu.wpi.first.wpilibj.I2C;
import edu.wpi.first.wpilibj.util.Color;
import com.revrobotics.ColorSensorV3;
import com.revrobotics.ColorMatchResult;
import com.revrobotics.ColorMatch;
This is a simple example to show how the REV Color Sensor V3 can be used to
detect pre-configured colors.
final public class ColorSensor extends TimedRobot {
private static ColorSensor instance_;
final public static ColorSensor getInstance() {
if(instance_ == null) {
instance_ = new ColorSensor();
return instance_ ;
private final I2C.Port i2cPort = I2C.Port.kOnboard;
A Rev Color Sensor V3 object is constructed with an I2C port as a
parameter. The device will be automatically initialized with default
parameters.
private final ColorSensorV3 m_colorSensor = new ColorSensorV3(i2cPort);
A Rev Color Match object is used to register and detect known colors. This can
be calibrated ahead of time or during operation.
This object uses a simple euclidian distance to estimate the closest match
with given confidence range.
private final ColorMatch m_colorMatcher = new ColorMatch();
private final Color kBlueTarget = ColorMatch.makeColor(0.143, 0.427, 0.429);
private final Color kGreenTarget = ColorMatch.makeColor(0.197, 0.561, 0.240);
private final Color kRedTarget = ColorMatch.makeColor(0.561, 0.232, 0.114);
private final Color kYellowTarget = ColorMatch.makeColor(0.361, 0.524, 0.113);
@Override
final public void robotInit() {
m_colorMatcher.addColorMatch(kBlueTarget);
m_colorMatcher.addColorMatch(kGreenTarget);
m_colorMatcher.addColorMatch(kRedTarget);
m_colorMatcher.addColorMatch(kYellowTarget);
@Override
final public void robotPeriodic() {
* The method GetColor() returns a normalized color value from the sensor and can be
* useful if outputting the color to an RGB LED or similar. To
* read the raw color, use GetRawColor().
* The color sensor works best when within a few inches from an object in
* well lit conditions (the built in LED is a big help here!). The farther
* an object is the more light from the surroundings will bleed into the
* measurements and make it difficult to accurately determine its color.
Color detectedColor = m_colorSensor.getColor();
* Run the color match algorithm on our detected color
String colorString;
ColorMatchResult match = m_colorMatcher.matchClosestColor(detectedColor);
if (match.color == kBlueTarget) {
colorString = "Blue";
} else if (match.color == kRedTarget) {
colorString = "Red";
} else if (match.color == kGreenTarget) {
colorString = "Green";
} else if (match.color == kYellowTarget) {
colorString = "Yellow";
} else {
colorString = "Unknown";
* Open Smart Dashboard or Shuffleboard to see the color detected by the
* sensor.
SmartDashboard.putNumber("Red", detectedColor.red);
SmartDashboard.putNumber("Green", detectedColor.green);
SmartDashboard.putNumber("Blue", detectedColor.blue);
SmartDashboard.putNumber("Confidence", match.confidence);
SmartDashboard.putString("Detected Color", colorString);
and here is my robot code
package frc.robot;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
The VM is configured to automatically run this class, and to call the
functions corresponding to each mode, as described in the TimedRobot
documentation. If you change the name of this class or the package after
creating this project, you must also update the build.gradle file in the
project.
final public class Robot extends TimedRobot {
private static final String kDefaultAuto = “Default”;
private static final String kCustomAuto = “My Auto”;
private String m_autoSelected;
private final SendableChooser m_chooser = new SendableChooser<>();
private I2C.Port i2cPort = I2C.Port.kOnboard;
This function is run when the robot is first started up and should be
used for any initialization code.
@Override
m_chooser.setDefaultOption("Default Auto", kDefaultAuto);
m_chooser.addOption("My Auto", kCustomAuto);
SmartDashboard.putData("Auto choices", m_chooser);
@Override
final public void teleopPeriodic() {
This function is called every robot packet, no matter the mode. Use
this for items like diagnostics that you want ran during disabled,
autonomous, teleoperated and test.
This runs after the mode specific periodic functions, but before
LiveWindow and SmartDashboard integrated updating.
String colorString;
@Override
This autonomous (along with the chooser code above) shows how to select
between different autonomous modes using the dashboard. The sendable
chooser code works with the Java SmartDashboard. If you prefer the
LabVIEW Dashboard, remove all of the chooser code and uncomment the
getString line to get the auto name from the text box below the Gyro
You can add additional auto modes by adding additional comparisons to
the switch structure below with additional strings. If using the
SendableChooser make sure to add them to the chooser code above as well.
@Override
m_autoSelected = m_chooser.getSelected();
// m_autoSelected = SmartDashboard.getString("Auto Selector", kDefaultAuto);
System.out.println("Auto selected: " + m_autoSelected);
- This function is called periodically during autonomous.
- This function is called periodically during operator control.
