Hopper Design
After last weeks TCNJ FRC District Competition. a few other team member and I had a though about changing our hopper design and adding a new human player feeder. and we came up with a design of a square hopper because it would have less areas of contact with a frisbee than a circle but still does its job of holding the frisbees in. It also solves many other problems we have been having with a circle hopper. How do you guys think about this? :confused:
Just go to Home Depot/Loweā€™s and buy a bucket like everyone else is. Itā€™s a solid solution that is cheap and easy. Also if you cut it wrong it just costs $5 to get a new one.
What problems have you had with the circular hopper?
We switched from a square hopper to a circular hopper after running into a lot of issues with frisbees not stacking particularly well in the square hopper and jamming the feeder. Square wasnā€™t the way to go for us. I think the more sides you have keeping it centered the better, and a circle has infinite sides.
Drawbacks: the circular hopper is tempermental to any pinching, so you have to be careful to keep it round with any attachments or fastening.
Get a five gallon bucket from Loweā€™s/Home Depot. (I recommend getting severalā€¦so you donā€™t hesitate to experiment/screw upā€¦they cost us less than $3 each.) The buckets are great because they taper only slightly, almost imperceptably from the top to the bottom. Put a disc into the topā€¦and it stops about 6 inches from the top. Draw a circle around the bucket where the disc stopped. Slice the bucket at this line or just above it, to establish the bottom edge of the hopper. (We used a Dremel with a metal disc cutter or sharp box cutter to cut the bucket.)
The slight taper in the bucket is nearly the perfect shape to keep the discs stacked, yet not nested so much that they do not separate or jam, and not so tight that they jam in the cylinder as they drop.
From there, experiment with an exit slot in the bottom (needs to be 1.4 inches high), a means to transition from the hopper to the chamber/shooter barrel (we use a pneumatic piston, without any clevis attached), and a means to feed it. For feeding, we cut about 225 degrees around the uphill and top edge of the bucket, cutting down about 1" from the top. With the sloped cover to the shooter, we have a good backstop for discs to hit, and drop into the hopper.
Dozens of examples are shown in the reveal videos. Your own geometry will vary, depending on you shooter configuration and space available on the robot.
We have been using a circular hopper made out of a 6 gallon bucket we found. We went through our district competition with one. And it had issues of the frisbee getting stuck and not falling in straight. So I was wondering if a square would be better.
Use a 5 gallon bucket from home depot / ace.
We prototyped square and it was a mess. Two days later we were back at a bucket. Rember that you canā€™t use the whole bucket, only the top 6 or 7 inches is wide enough to pass a frisbee without binding.
4343 and 1114 went the ā€˜dont stack the frisbeesā€™ route, which seems to be less jam-prone, provided you only index a single frisbee at a time into the pre-launch position of the shooter.
4343ā€™s design made human loading quick, and prevented the frisbees from jamming up their hopper by falling in sideways as is possible on many robots Iā€™ve seen.
Alright. thanks for the advice guys :slight_smile:
They only fell out the top :rolleyes:
Well, yeah. The indexer motor needed to be about 3" further down the hopper, and that problem would have been entirely alleviated.
we have a custom made sort of square shaped hopper, with ā€œstairsā€ that we built out of polycarb. hereā€™s a video where u can see how it works and stacks Frisbeesā€¦ altho iā€™m not sure iā€™m supposed to be sharing it :stuck_out_tongue:
We had a square hopper, but in order for things to work perfectly, it became very complicated. It also became very finicky, working one day and not the next. Weā€™re currently switching to a round hopper.
Good luck with what your trying!
Weā€™ve been using a square hopper and itā€™s been working pretty well for usā€“we tried the bucket method briefly, but decided it wasnā€™t really worth it for what we were trying to do. However, we do collect and shoot from the bottom (we built it for floor collection, but after Lone Star we decided that it might be better to human feed through the bottom slot, and itā€™s working quite well for us) and itā€™s powered, which helps make collection quick and reliable.
What are your dimensions for ur hopper?
Sudden thread revival time!
Iā€™m designing a new robot for our teamā€™s offseason events and have been interested in the square hopper design. I know 11 used it with success and a number of my friends prototyped it and it worked well for them as well. In the 2013 season we used a bucket and, while it ā€œworkedā€, it bent a lot and got pretty beaten up. I believe a strong, aluminum square hopper would pose little problems, though this thread has lots of people saying their square buckets didnā€™t work.
Now that the season is over, what is your opinion on square buckets? Has anyone who tried them had problems? If so, please describe the problems, and indicate whether the problems could have been attributed to another part of your robot rather than your square hopper, since that is a factor.
we used a square hopper this year and it worked out great once we figured out how to que discs in it. what we did was have the back wall that the frisbees fell into and hit be slanted and also have a small shelf that hung over the first frisbee and caught subsequent discs. the geometry made it so that only one disc could get in and virtually never jammed.
it ended up looking something like this from the side
ā€¦
__\
theres some good close ups of it in this video
I hereby disclaim that I have no experience with hoppers at all.
If youā€™re open to other, non-hopper solutions to holding disks, though, you may want to look at teams like us or 973, who stored disks in a line, not stacked on top of each other.
I can testify that our robotā€™s tray of disks worked well. There was only one match where we had trouble, and that was due to a piece of the orange polyurethane beltā€™s black electrical tape being ripped after two regionals and half a championship, with no maintenance. 973 was at Archimedes (we allied with them for eliminations) and both won LAR and were finalists at SVR.
You can see our robotā€™s videos on our Youtube channel, if youā€™re interested; I donā€™t know of any of 973ā€™s videos.
We are using a circular hopper and it worked great. However, we got one jam after champs and it got a little warped, so now it doesnā€™t feed right(as in, they stack 75% of the time instead of 95%). Itā€™s not even a visible difference. I guess I would suggest making the hopper slightly larger than needed (extra 1/4 inch dia. maybe) to compensate. Once it goes through the shooter, one as violent as my teamā€™s, anyway(look up video of us at midwest), that space isnā€™t going to affect the trajectory of the frisbee, anyway.
And we won one :wink:
