Anyone have ideas of how to get the hostbot and minibot to communicate prior to deployment? I would need 3 states, so a limit switch won’t do, two would though. I have also considered color, any other ideas?
You are allowed 2 light switches.
It may also be possible to hit buttons on an NXT, but that requires some nice precise positioning.
I might consider putting a countdown on the nxt program. Have every autonomous program set a delay in for 2mins and 5 seconds, after that no need to worry about turning it on right before the launch
Are these light switches at the driver station? ie can they be used to control it.
i actually need to control the minibot during the match.
Not sure what your planning on, but keep in mind G<46> MINIBOTS may only be used to climb the TOWER. Violation: Yellow card
Hmm, I wonder what defines using. Technically having a minibot on you as a 15lb counter weight is using it for something other than climbing.
Well that is just Physics we are planning the same thing but I don’t know how to either time it right or control it to do the climbing.
OK, how to use it for example:
You have a battery and motor connected through a push-type switch. Your Hostbot pushes the minibot on to the pole (say, with a pneumatic piston, or maybe a big rubber band…), and the pole presses the switch.
Depending on the rules, you can either use the switch to complete the circuit to power the motor, or you can use the switch to signal the NXT brick to turn the motor on (using the motor controller that’s allowed).
Hope this idea gets you started.
Not if you have a movable conterweight system. Then you are actively using your minibot to balance your robot. Personally I think the rule was meant to avoid minibot roaming the field during the endgame, but that’s just my personal opinion.
Yes it does thanks
ya you are right it is only to prevent minibots from roaming the feild
Thanks every body.
