Hi, Hooked up a ps4 t.flight thrustmaster to frc driver station, and the z-axis twist is not registering. This is only triggered by button presses on throttle stick. Any way to reconfigure input so twist is z-axis?
If you search for “Set up USB game controllers” in the start menu, you should be able to change which axes correspond to which inputs.
Check the button that glows green/red on the left side (throttle side). I believe it should be green. There’s also a switch on the back of the stick that should be set to the left (maybe right? I can’t remember) position. This fixed all our problems with the weird input stuff.
