How are your teams handeling Shuffleboard?
Our team is using Network table entry, but it looks way too much like copy paste code and I was wondering if there was a better way to do it.
public class ShuffleDisplay {
    private ShuffleboardTab shuffleDrivetrainTab = Shuffleboard.getTab("Drivetrain");
    private ShuffleboardTab shuffleIntakeTab = Shuffleboard.getTab("Intake");
    private ShuffleboardTab shuffleTurretTab = Shuffleboard.getTab("Turret");
    ShuffleboardLayout frontLeftWheel = _addLayout(shuffleDrivetrainTab, "Front Left Module", BuiltInLayouts.kList, 2, 2, 0, 0, Map.of());
    ShuffleboardLayout frontRightWheel = _addLayout(shuffleDrivetrainTab, "Front Right Module", BuiltInLayouts.kList, 2, 2, 2, 0, Map.of());
    ShuffleboardLayout backLeftWheel = _addLayout(shuffleDrivetrainTab, "Back Left Module", BuiltInLayouts.kList, 2, 2, 0, 2, Map.of());
    ShuffleboardLayout backRightWheel = _addLayout(shuffleDrivetrainTab, "Back Right Module", BuiltInLayouts.kList, 2, 2, 2, 2, Map.of());
    ShuffleboardLayout Important_ball_Info = _addLayout(shuffleIntakeTab, "Important Ballfo", BuiltInLayouts.kList, 2, 2, 3, 4, Map.of());
    public NetworkTableEntry drivetrainFrontLeftWheelVelocity;
    public NetworkTableEntry drivetrainFrontLeftWheelWheelPosition;
    public NetworkTableEntry drivetrainFrontRightWheelVelocity;
    public NetworkTableEntry drivetrainFrontRightWheelWheelPosition;
    public NetworkTableEntry drivetrainBackLeftWheelVelocity;
    public NetworkTableEntry drivetrainBackLeftWheelWheelPosition;
    public NetworkTableEntry drivetrainBackRightWheelVelocity;
    public NetworkTableEntry drivetrainBackRightWheelWheelPosition;
    public NetworkTableEntry calibrateButton;
    public NetworkTableEntry calibrateBoolean;
    public NetworkTableEntry setDeadband;
    public NetworkTableEntry Gyro;
    public NetworkTableEntry FieldOrient;
    public NetworkTableEntry ChassisSpeed;
    public ShuffleDisplay() {
        // Front Left Wheel Module Widgets
        drivetrainFrontLeftWheelVelocity = _addWidgetToLayout(frontLeftWheel, "Velocity", 0, BuiltInWidgets.kDial, Map.of());
        drivetrainFrontLeftWheelWheelPosition = _addWidgetToLayout(frontLeftWheel, "Wheel Angle", 0, BuiltInWidgets.kTextView, Map.of());
        // Front Right Wheel Module Widgets
        drivetrainFrontRightWheelVelocity = _addWidgetToLayout(frontRightWheel, "Velocity", 0, BuiltInWidgets.kDial, Map.of());
        drivetrainFrontRightWheelWheelPosition = _addWidgetToLayout(frontRightWheel, "Wheel Angle", 0, BuiltInWidgets.kTextView, Map.of());
        // Back Left Wheel Module Widgets
        drivetrainBackLeftWheelVelocity = _addWidgetToLayout(backLeftWheel, "Velocity", 0, BuiltInWidgets.kDial, Map.of());
        drivetrainBackLeftWheelWheelPosition = _addWidgetToLayout(backLeftWheel, "Wheel Angle", 0, BuiltInWidgets.kTextView, Map.of());
        // Back Right Wheel Module Widgets
        drivetrainBackRightWheelVelocity = _addWidgetToLayout(backRightWheel, "Velocity", 0, BuiltInWidgets.kDial, Map.of());
        drivetrainBackRightWheelWheelPosition = _addWidgetToLayout(backRightWheel, "Wheel Angle", 0, BuiltInWidgets.kTextView, Map.of());
         * Intake Ball info ShuffleboardComponent Boolean_1 = _addWidgetToLayout(Important_ball_Info,
         * "1 ball", BuiltInWidgets.kBooleanBox, Map.of()); ShuffleboardComponent Boolean_2 =
         * _addWidgetToLayout(Important_ball_Info, "2nd ball", BuiltInWidgets.kBooleanBox, Map.of());
         * ShuffleboardComponent Boolean_color = _addWidgetToLayout(Important_ball_Info, "ball color",
         * BuiltInWidgets.kBooleanBox, Map.of()); ShuffleboardComponent Swatch =
         * _addWidgetToLayout(Important_ball_Info, "Switch", BuiltInWidgets.kToggleSwitch, Map.of());
         * ShuffleboardComponent Swatch2 = _addWidgetToLayout(Important_ball_Info, "Switch",
         * BuiltInWidgets.kToggleSwitch, Map.of());
        // Calibrate button
        calibrateButton = _addWidgetToTab(shuffleDrivetrainTab, "Calibrate", false, BuiltInWidgets.kToggleButton, 1, 1, 5, 0, Map.of());
        calibrateBoolean = _addWidgetToTab(shuffleDrivetrainTab, "Calibrate 0/I", false, BuiltInWidgets.kBooleanBox, 1, 1, 5, 1, Map.of());
        Gyro = _addWidgetToTab(shuffleDrivetrainTab, "Gyro", 0, BuiltInWidgets.kGyro, 2, 2, 4, 2, Map.of());
        FieldOrient = _addWidgetToTab(shuffleDrivetrainTab, "Field Orient", true, BuiltInWidgets.kBooleanBox, 1, 1, 4, 0, Map.of());
        ChassisSpeed = _addWidgetToTab(shuffleDrivetrainTab, "ChassisSpeed", 0, BuiltInWidgets.kTextView, 1, 1, 4, 1, Map.of());
        // Deadband Slider
        setDeadband = _addWidgetToTab(shuffleDrivetrainTab, "Deadband", 0.1, BuiltInWidgets.kNumberSlider, 2, 1, 0, 4,
            Map.of("min", 0.01, "max", 0.25));
    private ShuffleboardLayout _addLayout(ShuffleboardTab tab, String name, BuiltInLayouts layout, int sizeX, int sizeY, int posX, int posY,
        Map<String, Object> props) {
        return tab.getLayout(name, layout).withPosition(posX, posY).withSize(sizeX, sizeY).withProperties(props);
    private NetworkTableEntry _addWidgetToLayout(ShuffleboardLayout layout, String name, Object defaultValue, BuiltInWidgets Widget,
        return layout.add(name, defaultValue).withWidget(Widget).withProperties(props).getEntry();
    private NetworkTableEntry _addWidgetToTab(ShuffleboardTab tab, String name, Object defaulValue, BuiltInWidgets Widget, int sizeX, int sizeY,
        int posX, int posY, Map<String, Object> props) {
        return tab.add(name, defaulValue).withWidget(Widget).withPosition(posX, posY).withSize(sizeX, sizeY).withProperties(props).getEntry();
Incorporate into actual shuffleboard.
RobotConstants.ShuffleDashboard.drivetrainFrontLeftWheelVelocity.setDouble(m_frontLeft.getDriveVelocity());
        RobotConstants.ShuffleDashboard.drivetrainFrontRightWheelVelocity.setDouble(m_frontRight.getDriveVelocity());
        RobotConstants.ShuffleDashboard.drivetrainBackLeftWheelVelocity.setDouble(m_backLeft.getDriveVelocity());
        RobotConstants.ShuffleDashboard.drivetrainBackRightWheelVelocity.setDouble(m_backRight.getDriveVelocity());
        // Update wheel angles on Shuffleboard
        RobotConstants.ShuffleDashboard.drivetrainFrontLeftWheelWheelPosition.setDouble(m_frontLeft.getTurnEncoder());
        RobotConstants.ShuffleDashboard.drivetrainFrontRightWheelWheelPosition.setDouble(m_frontRight.getTurnEncoder());
        RobotConstants.ShuffleDashboard.drivetrainBackLeftWheelWheelPosition.setDouble(m_backLeft.getTurnEncoder());
        RobotConstants.ShuffleDashboard.drivetrainBackRightWheelWheelPosition.setDouble(m_backRight.getTurnEncoder());
        RobotConstants.ShuffleDashboard.Gyro.setDouble(navx.getAngle());
        RobotConstants.ShuffleDashboard.FieldOrient.setBoolean(ControllerDrive.fieldOrient);
        RobotConstants.ShuffleDashboard.ChassisSpeed
            .setDouble(Math.sqrt(Math.pow(getChassisSpeed().vxMetersPerSecond, 2) + Math.pow(getChassisSpeed().vyMetersPerSecond, 2)));
        // Show if swerve is disabled on Shuffleboard and update when button is pressed
        RobotConstants.ShuffleDashboard.calibrateBoolean.setBoolean(m_swerveDisabled);
        m_swerveDisabled = RobotConstants.ShuffleDashboard.calibrateButton.getBoolean(m_swerveDisabled);
        RobotConstants.DriveConstants.innerDeadband = RobotConstants.ShuffleDashboard.setDeadband
            .getDouble(RobotConstants.DriveConstants.innerDeadband);
Maybe give Oblog a try.
