How can I implement the Curvature (Cheesy) Drive for an FTC tank chasis?
Someone could help me in knowing how to implement the Curvature (Cheesy) Drive in FTC for a chassis tank, if someone can pass me an example of Github or tell me how to do it, thank you.
Here’s how WPILib does it:
   * Curvature drive inverse kinematics for differential drive platform.
   * <p>The rotation argument controls the curvature of the robot's path rather than its rate of
   * heading change. This makes the robot more controllable at high speeds.
   * @param xSpeed The robot's speed along the X axis [-1.0..1.0]. Forward is positive.
   * @param zRotation The normalized curvature [-1.0..1.0]. Counterclockwise is positive.
   * @param allowTurnInPlace If set, overrides constant-curvature turning for turn-in-place
   *     maneuvers. zRotation will control rotation rate around the Z axis instead of curvature.
   * @return Wheel speeds [-1.0..1.0].
  public static WheelSpeeds curvatureDriveIK(
      double xSpeed, double zRotation, boolean allowTurnInPlace) {
    xSpeed = MathUtil.clamp(xSpeed, -1.0, 1.0);
    zRotation = MathUtil.clamp(zRotation, -1.0, 1.0);
    double leftSpeed;
    double rightSpeed;
    if (allowTurnInPlace) {
      leftSpeed = xSpeed - zRotation;
      rightSpeed = xSpeed + zRotation;
    } else {
      leftSpeed = xSpeed - Math.abs(xSpeed) * zRotation;
      rightSpeed = xSpeed + Math.abs(xSpeed) * zRotation;
    // Desaturate wheel speeds
    double maxMagnitude = Math.max(Math.abs(leftSpeed), Math.abs(rightSpeed));
    if (maxMagnitude > 1.0) {
      leftSpeed /= maxMagnitude;
      rightSpeed /= maxMagnitude;
    return new WheelSpeeds(leftSpeed, rightSpeed);
WheelSpeeds is a class containing two public doubles: left and right. Here’s MathUtil.clamp():
   * Returns value clamped between low and high boundaries.
   * @param value Value to clamp.
   * @param low The lower boundary to which to clamp value.
   * @param high The higher boundary to which to clamp value.
   * @return The clamped value.
  public static double clamp(double value, double low, double high) {
    return Math.max(low, Math.min(value, high));
