How can I install LabView another Pc
[FONT=“Comic Sans MS”]How can I install FRC’s LabView kit another compuer? I installed LabView but I couldn’t install the FRC version. I’m waiting for your help. [/FONT]
Did you install the FRC Utilities and LabVIEW update after you installed LabVIEW?
Here they are if you didn’t
You should be able to install LabView on as many team computers as you want. Make sure you do it in this order though:
  1. Using disc provided in KOP, install LabView. You will need the serial number to activate the product. This is in the KOP documentation.
  2. Download FRC updates from http://www.usfirst.org/roboticsprograms/frc/content.aspx?id=18758. Everyone must install the DriverStation updates and Utilities. Since you want to use LabView, download the LabView update as well.
  3. On each computer you that installed LabView, install the three updates.
  4. If using a different computer for the driver station that does not have LabView on it, you need to install only the first two updates.
No, but I’m installing now. But I installed (without it updates) a Windows XP operating system but I can just see “LabView”. I can’t see any FRC options
The LabVIEW FRC options come in the LabVIEW Update.
the DVD only installs basic LabVIEW.
Yes, I made updates and it still not. I explained my remaining part of the problem
re:
